Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
    Scrapped the buggy to swap the RZR
    Mods, if this belongs in the utv forum feel free to move it.
    After years (what seemed like decades) of collecting parts for the mini buggy build, I broke down and bought a RZR XP. A few months in it broke me......
    My story is this: PCV vent hose got pulled out of the airbox on a pretty hairy trail ride, I didn't notice it until it was too late. I'm not sure what the damage was to the 900 but since it had to come out it seemed like a good opportunity to upgrade.
    I had in my possession (minibuggy part collection...) 2.5 Yamaha RX-1 engines, a couple sets of Apex throttle body assemblies, adapters and air boxes from my brother's past endevours with HP3 Turbo Systems, and a burning desire to get some more power in this thing.
    In order to convert the Carburated RX-1 engine to EFI using yamaha Apex parts, and swap it all into the RZR I had to collect a few more parts, this is what I ended up with.
    For clutching I explored the following options:
    STM Primary and Secondary ---- This option was more than I wanted to pay considering how well we have made the Yamaha primary work in the sleds.
    STM secondary and Apex/RX-1 primary --- This option was cheaper than the first, but still maintains serious benefits over using a stock secondary.
    Dan at A&S racing told me he can mod your RZR XP TEAM Tied secondary to work with the wider belt used by the Yamaha for $150. This is the subject that started a war in my other thread.
    In the end I went with a STM clutch sourced from Jason at Hawk Engineering. I've never actually spoken with Jason on the phone, all of my contact has been via email or text, but he reminds me of a good 'ol boy. Stands by his word, communicates well, and is overall a pleasure to deal with. If you're thinking about doing something like this I would highly recommend looking his way.
    The Mount kit I have came from K&T performance. Randy, Rayce, and Kim are 15 minutes from my place, and are good people. Because of the relationship I have with them I got my mounts and a start for my turbo header through them. Their reputation stands for itself, you'll be hard pressed to find a harder working bunch of guys. They really are the real deal.
    If you find yourself in the situation that I'm in, and you have a RX-1 engine but want to run fuel injection, you'll need the following:
    Apex Throttle bodies, injectors, and sensors
    Apex intake CAM (has a missing tooth for the cam sensor)
    Apex Valve cover (has the hole for the cam sensor)
    Apex wiring harness/sensors (the apex and the RX-1 use the same p/n magneto, and flywheel as well as crank sensor. Also the Apex, RX-1, and R-1 all use the same cam sensor)
    Apex gauge cluster
    Apex ECU
    RX-1 to apex throttle body adapter. Val Simmons (owner of Simmons skis) is the only person I know building these things (see the intake side in some of the photos below).
    Once you have those pieces you should be able to get a RX-1 engine running on EFI.
    For the turbo kit I'll be using a twin scroll TD05H 16g with parts built by myself, and parts from a Brad Story/HP3/Simmons inc Apex turbo kit. I'll be running a Haltech Interceptor for fuel/timing control which will allow me to have maps for gasoline, and E85 fuel.
    Re: Scrapped the buggy to swap the RZR
    After a lot of back and forth, I decided to use a Haltech Interceptor Fuel/Timing controller instead of the Attitude/Dobeck box. The 3d tables and datalogging should make it a bit easier to dial the RZR in. It's not a standalone, but should get the job done.
    I chose a Deutsch Works D60 fuel pump to handle the extra fuel needed with E85, and what I hope to be nearly triple the stock 900 hp. It's quite a bit smaller than the walboro pumps, and will flow enough fuel to make 400whp on E85. The stock Apex Injectors are said to be somewhere in the neighborhood of 600cc/min which theoretically would support right around 260hp on E85 or 340ish on gasoline. This motor is staying stock so 260ish will have to do
    Like most things I take on thinking it will be a walk in the park, I'm starting to feel just how much work this is...........
    Motor is in, but trying to get all of this under the bed is looking to be a bag of fun..... :?
    I'm happy with where the Turbo is sitting in the photos, but the manifold is going to be tricky. Hopefully I'll have a better idea if it's going to work or not tomorrow.
    Feb 2007
    NW Washington
    That will be a ride...
    Oct 2008
    Ontario, Canada
    Cool!
    Holy Crap! That thing is going to RIP!!!!
    You better upgrade the suspension before you ever try to put that power to the ground. Get rid of the stock wheels, go to a 7.5" all the way around (I think it's 7.5...). This will get rid of the push. Go look at the 15" Method Beadlocks or the 14" Hipers. (search my XP thread - there's all the info you need in it.)
    Then go get the Exit Stage III suspension kit. It will take the horridly valved and sprung Fox's and make them work beautifully. It's over sprung and under damped. When you do the rear shocks, make sure you double the largest rebound washer, as the kit is just slightly underdamped and it will still tend to bounce a bit more than it should on a big landing. Put a real roll cage on it too.
    Looks awesome.
    And a mini-raptor body!
    Feb 2009
    Baton Rouge area
    i second the mini raptor body! i look forward to the video of this...
    Looks awesome.
    Thanks for the pointers, Suspension is planned, it's bad with the stock 900 in it. I have been looking really hard at the Exit kit, we've ridden snowmobiles with the Zollingers for years and I really try hard to support the local guys.
    I've had a hard time finding real world feedback on their kit. Any idea how it stacks up against the needle valve walker evans upgrade, or the Pep re-work kit?
    I'd really like a raptor body, but it's out of the budget on this one. I may try and do one on a 4 seater down the road.
    I will however be using Bens axle wraps or possibly even his up and coming axles on this.
    No clue on the comparison against the Pep's or Walkers, but I can verify, with many miles, that the Exit kit works very, very well.
    Get in touch with George at Double E Racing and he'll sell you a kit. The guy's really nice, knows his stuff and was very competitive on pricing. He's the one that suggested upping the rebound stack a tad and man, it works.
    I got the header finished up, now time to move on to the intercooler and intercooler piping.
    Here's some photos:
    Once I had a couple of the runners tacked I built a jig to finish it. I can't believe how much harder it is to weld in tight quarters like this. This is my first exhaust manifold and I think it shows..... :sad:
    And photos of it all welded and bolted up:
  2. off road buggy project help
    By miniracer1962 in forum Projects in Progress
    Last Post: 09-21-2011, 10:25 AM
  3. How Much for that Buggy in the Window?
    By darwinpayne2000 in forum MiniBuggy.net Lounge!
    Last Post: 03-11-2010, 09:30 PM
  4. buggy terms? street legal buggy need to find pic inside
    Last Post: 02-08-2009, 09:11 AM
  5. My new buggy/ kit car project
    Last Post: 01-07-2009, 07:22 AM
