Old 11-20-2008, 11:18 PM   #1 (permalink)
Default Trailing arm question
Hello everyone!
I'm in the process of designing my first buggy and I have a quick question. I know the stock length of a trailing arm is 16.25 in. centerline of pivot to centerline of hub. What I can't find however is the stock width. I've seen several ready made DOM trailing arms, 3x3, 3x5 ect., but I can't start laying out my frame in solidworks until I have the stock trailing arm width to work from. I've talked to peeps at Appletree, Dan's and others, but no one could answer my question or give me the dimensions of the ones they're selling??
Any help would be appreciated!
Thanks,
WT
wastintime is offline   Reply With Quote
Old 11-21-2008, 02:13 PM   #2 (permalink)
yoshi's Avatar
Default Re: Trailing arm question
Originally Posted by wastintime View Post
Hello everyone!
Thanks,
WT
width between center of mounts per arm?
www.sinistersandsports.com
Old 11-21-2008, 02:28 PM   #3 (permalink)
Hey yoshi,
No, actually the overall width. For example, from inboard face (ie. closest to the center of the chassis) of the pivot point to the outboard face of the bearing cup. I'm going to assume thats how the after market Manufacter's come up with the 3x3 over, 5x5 over ect. Please correct me if I'm wrong.
At this point I'd be happy with any measurment as long as I know how much over stock it is. I can just design my own arms and solve the problem, but kinda wanted to just order some prebuilt ones.
Thanks,
WT
Old 11-21-2008, 02:40 PM   #4 (permalink)
yoshi's Avatar
Hey yoshi,
Thanks,
WT
I may be wrong, but I always assumed 3x3 over meant 3" wider, 3" longer than stock....
Old 11-21-2008, 02:50 PM   #5 (permalink)
It does, but until I know the stock width the 3" over does me no good. For example, I know stock length centerline of pivot to centerline of bearing carrier is 16.25. Therefore a 3x3 is 19.25 long center to center but what is the width?
Thanks
WT
Old 11-21-2008, 03:08 PM   #6 (permalink)
Maybe this will help. This is the measurement I need. If someone has a 3x3, a 5x5 or whatever and has this measurment from their arm, I can figure stock width from there as long as I know how much over it is. Or just knowing the stock width will tell me how wide a 3x3, 5x5 ect. is.
WT
Old 11-21-2008, 05:17 PM   #7 (permalink)
I will try to measure my 5x5s today for you and let you know
punkur67 is offline   Reply With Quote
Old 11-21-2008, 05:21 PM   #8 (permalink)
Thanks a lot punkur!
Last edited by K-fab; 11-22-2008 at 04:19 PM. Reason: The speeling Nazi strikes! :)
Old 11-22-2008, 05:09 PM   #9 (permalink)
The spelling nazi struck my post......unfortunately he didn't spell spelling correctly!!!......LOL
WT
Old 11-23-2008, 04:37 AM   #10 (permalink)
I measured from the center of the inner pivot to the bearing cap and got about 23". Did you want to wheel mounting surface? I can pit a hub on tomorow and get you that if you want.
Trailing arm vs semi trailing arm LockedupXJ Suspension - Wheels & Tires 11 08-14-2008 06:26 PM
Trailing arms elmariachi Suspension - Wheels & Tires 18 07-22-2007 11:36 PM
Chain driven trailing arm LEE1969GB Driveline 5 01-19-2007 12:04 AM
Changing trailing arm lengths. buildstoys Suspension - Wheels & Tires 6 09-09-2006 02:35 AM
Question on the rear trailing arms for a Panther. plkracer Suspension - Wheels & Tires 3 08-14-2006 04:14 AM
