Old 08-20-2008, 12:48 AM   #1 (permalink)
Default slow leak tires
I have a one old tire that has a slow leak that i can not seam to stop it will be flat in 2 day time. (slime) did not work and i replacedthe valve stem no luck there. What else can i try??
One of the new tire and rim set that i got and have ever use slow leaks also not as fast as the above, Any thoughts????
jerry is offline   Reply With Quote
Old 08-20-2008, 12:52 AM   #2 (permalink)
masterfabr's Avatar
Default Re: slow leak tires
50/50 mix of regular antifreeze and Alumiseal ALUMINUM radiator sealant.Mix well.Put about 1 cup in the tire and drive it for a while.Clean out ALL the slime first.
Old 08-20-2008, 12:54 AM   #3 (permalink)
arrowhead's Avatar
Jerry
Get an inner tube from your local tire store
I put tubes in all my sand tires 5 years ago and it ends the constant filling forever
Implement tubes fit the 1300 paddles
Old 08-20-2008, 12:54 AM   #4 (permalink)
Some guys mix up water and alumaseal (meant for radiator)... I've never done it, but lots of guys swear by it. do a google/glamisdunes search to get the exact recipe.. Your problem is not uncommon- good luck.
Radiodude is offline   Reply With Quote
Old 08-20-2008, 12:55 AM   #5 (permalink)
I think master just nailed it..
Old 08-20-2008, 01:08 AM   #6 (permalink)
Masterfabr: after running it awhile just leave the stuff in or take it out.
THANK YOU
Old 08-20-2008, 01:35 AM   #7 (permalink)
Where is your leak exactly?
If it's at the beads,I use silastic.Clean both rim edge and tyre bead,thinly smear some silastic on both mating edges and inflate and leave for 24 hrs.
I did mine on some OEM old and bead damaged tyres/rim from my 350 Ody a while back as a temp repair.It doubles as a beadlock and flexible sealer.It handled ALL my driving/jumping for over 7 months,till I remembered that I should get a new tyre...Baz
bazz is offline   Reply With Quote
Old 08-20-2008, 02:16 AM   #8 (permalink)
masterfabr's Avatar
THANK YOU
Leave it in. If AND when it tries to leak it will quickly seal up any future leaks.The stuff will not harm the tire or be corrosive to the wheel nor will it dry out. Works especially at sealing up beadlocks.
Old 08-20-2008, 06:32 AM   #9 (permalink)
Last year i finley got tired of airing up my riding mower rear tires every couple of weeks and took my wheels off axle and sumeraged in tub of water to find out that both tires were leaking at the bead, which didn't suprise me but also found out that air was coming out of sidewall in several places( one place around the lettering on sidewall) Probabley from running over stoubs and hittint the fence posts. The leaks in the sidewall explaines why the slime never worked( slime only seems to work on the tread area)so i laid the tires on one side for an hour then turned them over for an other hour to let the slime work on sidewall leaks and the beads, long story short answer is they have been holding air for 13 months now.
Just got to get slime to where the leaks are, right...
boilermaker is offline   Reply With Quote
Old 08-21-2008, 03:20 AM   #10 (permalink)
Drillspot.com has the stuff in a 16oz size for $4.02. I can not find it local in any thing but the small tube.
DOT Tires? Section 8 Suspension - Wheels & Tires 4 08-12-2008 12:54 AM
Tires and wheels size buggito Projects in Progress 24 01-08-2008 03:44 AM
run small (ATV) tires, OR regear and run taller tires? Radiodude Suspension - Wheels & Tires 9 12-19-2007 12:42 AM
full size desert tires for 14in. wheels Damien Suspension - Wheels & Tires 1 04-03-2007 07:33 AM
Paddle tires and alum. wheels pato Suspension - Wheels & Tires 0 01-22-2007 03:01 PM
