Old 08-09-2008, 10:59 PM   #1 (permalink)
Default CV degrees of operation
When a CV has 25° as it's operating range, does that mean total deviation from 0°, or is it ±25° from 0°, totaling 50° of deviation?
anasasisxenophontis is offline   Reply With Quote
Old 08-09-2008, 11:06 PM   #2 (permalink)
masterfabr's Avatar
Default Re: CV degrees of operation
the latter
Old 08-09-2008, 11:11 PM   #3 (permalink)
busasandrail's Avatar
I believe its the latter.....having 25 degs. off 0 in any direction
Nothing is impossible---it just costs more money.
EL TORO sand car w/(soon to be) TURBO 1397 Busa / Subaru STI diff. / cutting brakes
www.eltorosandcars.com
Old 08-09-2008, 11:15 PM   #4 (permalink)
All right, good. CVs are far more capable than I thought they were.
Old 08-09-2008, 11:25 PM   #5 (permalink)
Admin
Gene's Avatar
If your carrier is forward or back from the axle centerline it will add degrees. Also it is probably a bad idea to go beyond 23 to enhance reliability.
Old 08-10-2008, 05:14 AM   #6 (permalink)
I have always been told that you loose angle as you move your hub or trans off center cause you now have to take the offset of the cvs into account also. The advantage is that you can run sometimes longer axles allowing more wheel travel per degree of angle.
punkur67 is offline   Reply With Quote
'cheating' cv angles/ axles front to back Radiodude Driveline 31 01-04-2008 11:48 PM
rear suspension design joeygo Suspension - Wheels & Tires 54 05-14-2007 09:48 PM
Sand-Bug #1 Kludge Projects in Progress 218 04-10-2007 09:10 PM
Caster angles? plkracer Suspension - Wheels & Tires 6 08-18-2006 11:26 PM
Front kick up in degrees? plkracer Suspension - Wheels & Tires 24 08-04-2006 12:45 PM
