Ummm, not on this planet they don't. Torque reaction is caused by the differential to whatever it is mounted to. Unless you have it mounted to the trailing arm (Tomcar) then there will be no torque effect. Now outboard brakes on the other hand.......
#2 (permalink) | |
I was wondering if anyone was going to point that out.
An open mind is a virtue-----so long as all the common sense has not leaked out! |
#6 (permalink) |
I do.Surprised you don't.I'll tell you this though ,it ain't from torque reaction. Now can you tell me why? If not, post a side pic of the drak.
#7 (permalink) |
I believe it is actually caused by the fact the outer cvs are about 4 inches forward of the inner cvs, causing a torque lift to the rear end....Should we start a new thread, cause i know your going to make 30 posts arguing with me.... I got to crop a video then ill post it....
Parts and accessories available in the classified section......
#8 (permalink) |
^^^^^^^^^ LOL! It ain't from torque.Post up the pic in a new thread.This is actually a good topic to discuss. I'm going to eat.Be back in 2-3 hours.
#9 (permalink) |
I should have said from torque reaction.Take a wheel off and post a side pic from the front suspension mounting points to the rear hub area. If you don't have a pic like that just a side pic should do.
| Rear Trailing arm toe. | punkur67 | Suspension - Wheels & Tires | 56 | 08-06-2008 12:36 PM |
| Torque.......2 into 1 or 2 seperate pipes? | Pacman | Motor - Engine | 14 | 08-23-2007 03:42 AM |
| Torque mutiplication Thru a jack shaft | Bugpac | Driveline | 27 | 08-20-2007 10:40 AM |
| Comet Torque Converter Model 40 help | Brawler | Driveline | 1 | 04-04-2007 10:38 PM |
| Motor Preferences | KWiKSand | Motor - Engine | 11 | 04-04-2006 03:13 PM |
