Old 08-03-2008, 08:02 AM   #1 (permalink)
Default Critique this suspension setup please
Anyone see a problem with running this setup with the arms offset. disregard this shock being to long. I am just wondering about how the arms are setup? I want the room to have the option to run a bypass shock. I have 6 degrees of caster, 6 degrees rake, good camber change etc and plenty of room if I setup like this. Whatchoo think?
Old 08-03-2008, 12:46 PM   #2 (permalink)
Default Re: Critique this suspension setup please
How is your rack going to fit in? And what type are you going to use?
Old 08-03-2008, 01:51 PM   #3 (permalink)
yoshi's Avatar
That's how I do mine....
I run 9 degrees caster and 12 degrees rake....
critique-suspension-setup-please-arms-2.jpg  critique-suspension-setup-please-front-arms..jpg  critique-suspension-setup-please-frame-2.jpg
www.sinistersandsports.com
Old 08-03-2008, 02:28 PM   #4 (permalink)
Administrator
K-fab's Avatar
Absolutely nothing wrong with it. In fact, it's a great setup, as it loads the chassis in a wider area instead of the arms being directly above each other.
Many of the full size desert vehicles - TT, Class 1, Class 10 run setups similar to what you've drawn.
Looks good.
Old 08-03-2008, 04:17 PM   #5 (permalink)
masterfabr's Avatar
That's how my favorite car is done.Too bad Mosebillt is now out of business.
Old 08-03-2008, 04:42 PM   #6 (permalink)
yoshi's Avatar
Eh?
He just started a log on a new build.
http://www.glamisdunes.com/invision/...&#entry2896942
Old 08-03-2008, 04:58 PM   #7 (permalink)
masterfabr's Avatar
The partners split ways.Their builder and a couple guys are trying to continue on under their name from my understanding. I wish him luck.But the mosebillt partners are no more. Things are getting tough in the full size market.
Old 08-03-2008, 04:58 PM   #8 (permalink)
masterfabr's Avatar
THat's why Tut's out of a job there.
Old 08-03-2008, 05:10 PM   #9 (permalink)
yoshi's Avatar
Then mosebilt's not out of business, just restructuring. Doesn't look like they are slowing down on projects..
"peter North Series" Trailing Arms - GlamisDunes.com
Old 08-03-2008, 06:51 PM   #10 (permalink)
Right on. Yoshi, I must have never noticed that yours were like that. Did you recently change that? I have noticed the big class 1's and TT's like that though. It made alot more since to me to set it up like that.
Not sure on which rack to use yet. But there should be ample room for whatever I choose. Anyone know what small PS racks are out there that are more suited to the minis?
Need Help with front Suspension setup RG500 Suspension - Wheels & Tires 7 02-03-2008 06:33 AM
How do i setup my rear suspension Jay1823 Suspension - Wheels & Tires 36 10-31-2007 08:09 AM
Possible Summer SSC Suspension Redo dlisabeth Suspension - Wheels & Tires 13 06-12-2007 04:33 AM
How do you know if your suspension is good or not? BoneDuner Suspension - Wheels & Tires 8 12-28-2006 07:00 AM
Shock placement in relation to Suspension movement K-fab Suspension - Wheels & Tires 30 11-20-2006 06:24 PM
