I just started putting in a set of 5 x 5 trailing arms and they look like they have way too much toe in. They are heimed outside and are adjustable but I want them close before I tack the inner buckets in so I dont smash up the poly bushings. Does anybody have a recomended toe for the rear?
#6 (permalink) |
Its a sand and dirt rig. I know im being a traitor but im going with a 2.0 twin turbo subaru rear hung with a 091 trans. 113" wheelbase 2 seater. It will be sitting on a set of 16" 2.5 king piggybacks. It will be used mainly in the sand
#7 (permalink) |
Rear end: Toe in helps the car come out of the corner better, toe out helps the car go into the corner better. Front end is just the opposite.
I'm w/BDK - 0 at ride height unless you're short coursing, then adjust accordingly, but start at 0.
#8 (permalink) | |
On something like a short course buggy with limited travel, you might want to play around with it a little more. |
| Chain driven trailing arm | LEE1969GB | Driveline | 5 | 01-19-2007 12:04 AM |
| Rear Trailing Arms | Hipshot6 | Suspension - Wheels & Tires | 62 | 01-07-2007 10:47 PM |
| A-arm vs trailing arm rear suspension | Havis | Suspension - Wheels & Tires | 5 | 12-26-2006 04:49 AM |
| Question on the rear trailing arms for a Panther. | plkracer | Suspension - Wheels & Tires | 3 | 08-14-2006 04:14 AM |
| Rear A arms vs trailing arms | tarponslayer | Suspension - Wheels & Tires | 35 | 05-27-2006 12:01 AM |
