#6 (permalink) |
Yup, BDK nails another one.
#7 (permalink) |
Sorry but you will have a lot of axle plunge which means if the spline will handle it the drive and driven flange will have to have a deep pocket to handle the axle ends and it will also raise hell with the cv boots,
Also it looks like your lower arms have rod ends at both ends which means that those lower bars must be X braced and locked together or you will wind the whole works up the first time you let the clutch out or the other alternative would be to install two bars forward then they would be ok as is I would really think you should consider moving those inner pivot points so they are directly inline with the inner cv I just spent some time correcting a rail that had this exact problem Good Luck |
#9 (permalink) |
Ok so, I'm trying to understand this... You're just looking at the picture and judging movement from what you see, right? I can tell that there might be some plunge in the CV...I assume that is because the inner CV isn't in-line with the A-arm inner pivots. Also, what is a cycling issue? And with the camber measurement, is that going to change because the upper A-arm is shorter than the bottom? Forgive me if I ask a bunch...just making sure I understand the suspension geometry here. I know it could be a disaster if it isn't set up right, and a wreck to fix if not designed right...
#10 (permalink) | |
| rear diff idea for my truggy | jumpin jellybean | Driveline | 7 | 07-17-2008 02:16 PM |
| Frame Idea 2 | plkracer | The Drawing Room | 21 | 05-04-2008 05:47 AM |
| Rear Swing Arm (Chain Driven) | ChillItsGill | Driveline | 59 | 04-15-2008 05:11 AM |
| rear axle idea... | yoshi | Driveline | 10 | 08-22-2007 09:01 PM |
| rear suspension idea... | yoshi | MiniBuggy.net Lounge! | 18 | 09-08-2006 01:49 AM |
