Old 05-20-2008, 04:20 AM   #11 (permalink)
masterfabr's Avatar
Default Re: mounting shocks
If the tabs are 1/8" yes OK .I think they look to be only 14 Ga. Maybe I'm just judging the thickness wrong.
Old 05-26-2008, 06:23 PM   #12 (permalink)
This maybe silly but i am asking any way, I temporarly mounted 1 shock and need to see if iam at 90 degrees at full bump, but i can not compress the shock enough do ijust release the gas through the bleeder valve and then later just recharge later???? will i loose any oil ????
jerry is offline   Reply With Quote
Old 05-26-2008, 06:46 PM   #13 (permalink)
bdkw1's Avatar
Yes, let the nitrogen out. If you have it upright and let it out slowly, you won't lose much if any oil. If you are running air shocks, you might want to consider getting a nitrogen tank and regulator to fill your own shocks as you will be making adjustments later on. It makes life much simpler if you have your own bottle.
Old 05-26-2008, 09:31 PM   #14 (permalink)
Admin
Gene's Avatar
Another option is to use a piece of metal strap with three holes. The upper two holes represent collapsed and extended length. This is a lightweight way to move things around and you can easily put a square or protractor against it. Of course you still have to iron out clearance issues . . .
Old 05-27-2008, 01:25 AM   #15 (permalink)
Tell me what you think look good or what???
mounting-shocks-shock1.jpg  mounting-shocks-shock2.jpg  mounting-shocks-shock1.jpg
Old 05-27-2008, 03:56 AM   #16 (permalink)
Doug Heim's Avatar
I believe you may be putting too much rotational load on that tube that the mount is tied to. I know how I would do it but I would have a hard time explaining it. I wish I were there to explain in person. Wish I was of more help. Ill see if I can draw it up in a way it would be seen and explained well.
Please visit the classifieds section to view items I have available for purchase. I accept all major credit cards & Paypal.
Doug Heim is offline   Reply With Quote
Old 05-27-2008, 05:17 AM   #17 (permalink)
bdkw1's Avatar
Close, your pivot lines should actually be through the arm pivot and the shock mount pivot like so.
Also, on thin wall tube, long tabs like those can rip a section of wall out of the tubing. It would be better if you could put a piece of tubing across between the tubes you just put in and mount the tabs of that co that they are pointing strait down.
Old 05-27-2008, 01:27 PM   #18 (permalink)
Thank you for the input, ( you guys are giving mejust what i want and need) i will redsign again. Mounting shocks is no fun... It is like 2 steps forward 1 step back then start over
Old 05-27-2008, 01:44 PM   #19 (permalink)
masterfabr's Avatar
Beef up the upper mount and IMO you've got it.There's been some really good advise given in this topic.Good going guys!
Old 05-27-2008, 01:59 PM   #20 (permalink)
I am not sure how to beef up mount. The advis has been great *thank you all
