Front arm, steering rack modified down to 14"
Read some where that using a-arm length and angles from heim that multiply the arm length times the tangent of the heim angle to determin the maximum wheel travel. Might finally get to use trig from school. ![]() |
#6 (permalink) |
That's hard to believe unless you are talking about both ways? I know with a 1/2 inch spacer, you can get 28 each way, and around 34 if you go to a 3/8.
#8 (permalink) |
[url=http://www.mlmotorsports.biz/:7o81vk0q]Here, go to high misalignment spacers.[/url:7o81vk0q]
#10 (permalink) |
http://www.rodendsupply.com
I can get anything from there. 27 degrees for 5/8" with 1/2" bolt hole mis alignment bushing. That is one way so it would be 54 degrees both ways. They list all the specs on the heims and the bushings in the catalog. |
