Old 12-10-2007, 08:35 PM   #1 (permalink)
Default 30" BFG's on 4" wide wheel
I am getting ready to order some wheels and could use some help. Is a 4" wide wheel to narrow for a 30" BFG? I know BFG recommends a 5.5 or 6 minimum but I assume that is for street use.
Thanks
MXman is offline   Reply With Quote
Old 12-10-2007, 08:38 PM   #2 (permalink)
plkracer's Avatar
Default Re: 30" BFG's on 4" wide wheel
That seems very narrow. The tread may not end up flat on top, but you should be able to get it on.
It finally moves!
Old 12-10-2007, 09:37 PM   #3 (permalink)
Super Moderator
minibajaman's Avatar
How wide is the tire? *Either way 4" does seem really narrow, I don't even know what rims come in that narrow of a width. *It will give the tire a more rounded profile and possibly handle poorly as well.
Old 12-10-2007, 11:18 PM   #4 (permalink)
Likely it is going to make the tire about 35" tall as well... *I am guessing you need 6" at minimum depending on the tire itself...
Old 12-10-2007, 11:29 PM   #5 (permalink)
bajatex's Avatar
It will work just fine and the overall height won't change much. *If you are going to run the tires tubeless the narrow rim helps keep the bead on, if you are talking about the BTR non beadlocks
Bajatex
bajatex is offline   Reply With Quote
Old 12-11-2007, 12:30 AM   #6 (permalink)
tire roll?
hero_saku39 is offline   Reply With Quote
Old 12-11-2007, 12:39 AM   #7 (permalink)
Bajatex
Thats exactly what I thinking / hoping. I was talking about the BTR's as well. I may go with the 275 / 70 / 15 tires which are supposed to be about 29" tall.
Tex do you know if anyone has them in stock?
Old 12-11-2007, 01:14 AM   #8 (permalink)
bajatex's Avatar
The last time I was in the Escondido ORW store they had some.
Bajatex
Old 12-11-2007, 04:48 PM   #9 (permalink)
Am I wrong in thinking tire roll will be a big issue here??
Old 12-11-2007, 05:49 PM   #10 (permalink)
bajatex's Avatar
These are a 33x10.5 tire on a 4" BTR. *There are a lot of people that race with the 4" wheels mounted with 10.5 or 9.5 tires.
