I glossed over that site and noticed a few things, to adjust your pressure you need the proper tool to depress the valve core so you can accurately adjust and maintain the pressure his methods might be good enough for a slow moving rock crawler but you will want something more accurate for a buggy especially if yours is like my Pilot 600 lbs.
That site has alot of good info on it you guys should feel lucky to have it to look at, back when I bought my shocks I didnt get that sheet telling you to add oil or how to adjust, their was NO info on the web to be found on the air type shock, *I just got shocks in a box then had to call FOX to try and pry info out of them, after calling them two times I quit calling, the best info I got came from another Pilot Odyssey member that had them on his LT Pilot, trust me their is a alot difference betweem looking at that page and looking into a empty card board box. |
I see they offer 2.5 air shocks now "Double The Load Capacity Of The 2.0 Air Shocks"
http://www.polyperformance.com/shop/pro ... amp;page=1 |
#4 (permalink) | |
The image link to something in this site SHOULD work - but as you've seen, nope. Nada. - Hopefully when Amergin updates the php software, this bug will go bye bye. Here's the pic you were trying to get to show (I cheated, d/l'd the pic, attached it to an outside website and then linked from there): ![]() As hoser points out - this little piece is absolutely necessary when trying to adjust air shox. You can NOT tune them correctly w/o a setup that keeps the system closed while adjusting.
#9 (permalink) |
Sweet! Is that the one with the nitrogen filtering kanebler valve on it?
This what the good guage on the regulator is for. set your regulator to the desired pressure, bleed it a couple times to make sure the pressure holds, fill shocks. It will be just as accurate as the assymbely above. |
#10 (permalink) | ||
