I am using the wide five hub assembly from Tatum on the rear of my mini, and I want to know if I can put a 12" diameter wheel instead of the 15" that is currently on it? The 15" wheel with a 14.50 tire is way too large for this car, I need a 12" wheel and about a 26" tire. What bolt pattern do most mini manufacturers run, because it looks like most use a 12" wheel not the 15" in the rear.
Kevin |
#6 (permalink) |
yeah but you can gear the buggy higher with the smaller tire or gear the buggy lower with the bigger tire and come out the same right you just change sprockets as well as tires i thought. so why would a busa need a large tire. i thought it just needed to be geared right depending on whatever tire you have no matter what motor you pick
#8 (permalink) |
12'' wheels with a 5 lug vw pattern isnt a off the shelf part, in fact i dont think there is enought room. You might call tatem about a pair of 4 lug hubs and sell the others. 1300x15 tires are a lot of rubber for a mini, when the rpms are down their really going to hurt what little low end there is. Also the gearing is going to be difficult without some form of reduction box or jack shaft. If your are building a heavy car and running 26'' paddles the wider pros are good for more flotation, also going to add more bite. As far as top end speed the smaller tires are faster.
#9 (permalink) | |
#10 (permalink) |
Kevin,
Too big in what way? Too: wide, tall, heavy or need too much HP to spin them up? You could drop down to a 13.00-15 and have them cut for the power you have. /Frank
You know you are blessed when your wife loves you and she understands your need for tools and a shop! Coming Soon www.minibuggysupply.com |
