All the builds I see have front steer, tie rod and steering arm in the front of the wheel center line.
Is there an advantage? I would think rear steer would be better because the tie rods are within the a-arms for protection. I will have front steer in my car but that is only for foot room. |
#2 (permalink) |
If you are runing powersteering or hydralic you can run both; all you have to do is swap the lines. If you run a "normal" rack in the rear, it would turn the opposite; you turn left car goes right etc.. I guess it could be fun watching your passengers reaction.
#4 (permalink) |
IMO, I think that front steer would be stronger. If you hit something with your front tire with rear-steer, the tie rod bends in a heartbeat. With front steer, it would be a lot harder to bend.
My RR has rear steer, mainly due to limited space, but I've bent my tie rods a number of times. I will be replacing them with something stronger, but then I'll have to worry about where the stress is being transfered. |
#5 (permalink) | |
#6 (permalink) |
I was under the impression that rack and pinion steering boxes are like straight cut gears only flat. So, they shouldn't know if they're pulling or pushing.
In road racing there is a following for each type of steering. Some front steer guys say the 'turn in' is sharper. Rear steer guys sy that it's more accurate on speedways. But nobody ever said anything about directional racks. I heard it was strictly for packaging. DG |
#7 (permalink) |
[quote="dirtguy"]I was under the impression that rack and pinion steering boxes are like straight cut gears only flat. So, they shouldn't know if they're pulling or pushing.
The rack does not care either way. When you hit something big with the tire, the tie rod in a rear steer will some times fold. Pretty common in Baja Bugs on the long side. If the tie rod runs along the front the rod will not stretch, it just pulls the wheel out of your hands. I'm not saying they never fail, just the rear steer tie rods are more likely to fold. There are many racks. Baja Bug rear center, not a good candidate for conversion. Some front steer racks are best not converted either. |
#9 (permalink) | |
