Thread: A Arm tubes
Results 1 to 3 of 3
    A Arm tubes
    Hi im currently building an st4 and im starting to build the a-arms but the plans call for a weird size of rectangular tubing which i cannot find in my country so i'm thinking of using two angle bars plasma cutting them to the right size then clamping them together with a piece of wood in the middle so the size is right then welding them together to form a rectangular tube.
    What do you guys think about this, will it be strong enough?
    P.s
    I cant use a different size of tubing because i have already machined the bushings and bushing holders
    thanks
    Re: A Arm tubes
    Sep 2008
    Allendale MI
    This sounds a lot like something you would see in the desert racing community. This is a labor intensive way to do it, but if built right they are very strong. I don't see any reason that wouldn't work.
    Justin
    Nowhere near the desert.
    Re: A Arm tubes
    Feb 2009
    Baton Rouge area
    I agree with deranged. I think it will be fine.
  1. What size of tubes to use
    By gvouvakos in forum Frame
    Last Post: 04-24-2012, 11:35 AM
  2. 1 tube vs. 2 tubes
    By pooologist in forum Frame
    Last Post: 05-18-2010, 05:46 PM
  3. The push pull thing about tubes
    By TEO in forum Frame
    Last Post: 02-15-2010, 10:51 PM
  4. What to fill the chassis tubes with?
    By Rorty in forum Frame
    Last Post: 01-06-2008, 02:42 AM
  5. Redrawing tubes with CAD?
    By plkracer in forum Frame
    Last Post: 01-03-2007, 09:15 PM
