Results 1 to 5 of 5
    limit strap mounts location
    Jun 2007
    san diego
    I need some advice on the limit straps I am going to mount.
    Typically I have seen the adjustable mount for the strap on the top and just a tab for the bottom on the trailing arm but I would like to swap that around and out the adjustable mount on the trailing arm and the tab on the frame.
    The strap would be parallel to the shock.
    Does it really make a difference?
    TIA,
    JJ
    2006 Sinister Sand Sport
    2009 Joylaris
    2004 YFZ450
    2004 Raptor 350
    Re: limit strap mounts location
    Other than having to stand on your head to adjust them?, nope.
    Senior Member NoClue's Avatar
    Aug 2008
    Fullerton, CA
    Quote Originally Posted by jjstime View Post
    I've been wondering about this part of mounting limit straps. I'm sure it all depends on what time of room and mounting points, but would shooting for 90* at full droop? Like for rear trailing arms, the the straps frame mounting point would come from the rear?
    Jun 2007
    san diego
    When I said parallel to the shock I meant at the same angle.
    Will post a picture when I get it on spot welded
    2009 Joylaris
    2004 YFZ450
    2004 Raptor 350
    Petoskey, Michigan
    While the differance in weight between the two ends IS small they claim that loosing one pound off the moving suspension is like loosing ten pounds off the chassis.
    Unsprung weight vs sprung weight and all.
  1. ZX Engine mounts size dimensions
    By sosasser in forum Motor - Engine
    Last Post: 12-05-2012, 08:50 AM
  2. fl 250 engine mounts
    By flyingw in forum Honda's Pilot & Odyssey
    Last Post: 03-28-2012, 02:19 PM
  3. sled engine mounts
    By Stomper in forum Motor - Engine
    Last Post: 03-12-2012, 09:15 PM
  4. Another Mini
    By Gene in forum Projects in Progress
    Last Post: 02-21-2010, 08:31 PM
