Results 1 to 8 of 8
    Trying to use some Fox Podium X's - Spring ?
    I picked up a full set of Podium X shocks off of a Polaris Outlaw 500 that I'd really like to use.
    Obviously the spring rate is wrong, but I installed the back and the tender spring is fully collapsed and I don't have a great feeling about the main spring as I had to add a lot of pre-load to make the buggy sit up reasonably well. About 800 pounder. Not a long travel buggy.
    Are there reasonably priced higher rate springs for these shocks? When I called Fox, they were nice enough but gave me the "That's a Polaris thing and you have to get springs from them" story. Not good enough.
    Anyone know where I could get springs?
    Re: Trying to use some Fox Podium X's - Spring ?
    Member mini929honda's Avatar
    santa cruz, ca
    Are they the fronts or rears? the rears are a 2.0 shock body and use a 2.5" spring. fox and king. Here is a pic of a custom fox podium with 2.5 spring
    Well,
    I'm putting the rears, on the rear and the fronts, I guess....on the front. :-) The non-smart arse answer is "both".
    I think you answered my question, though - just get the diameter of the springs and length and then I need to figure the rate out.
    Any ideas where to shop for the springs at a decent price? How about spring rate for the main and tender spring?
    Suspension Spring has a good assortment of sizes at good prices.
    Thanks - I'll check them out.
    Website available? Searched but nothing obvious yet.
    Thanks
    Try Suspension Spring Specialists
    Thanks - I finally figured that out late yesterday. Looks like they've got what I need - I see they have a "suggested price" - any tips on dealers that offer a good discount or will SSS "discount" when you call?
    Also, the current springs on this shock just look way too short for the shock body; I'm guessing the spring rate does not reduce much with length, but rather material diameter and number of coils per inch???
    Thanks for your help.
  1. Another Mini
    By Gene in forum Projects in Progress
    Last Post: 02-21-2010, 07:31 PM
  2. Driven clutch spring
    By duner651 in forum Driveline
    Last Post: 12-16-2009, 08:43 PM
  3. SAE Baja Buggy Spring Rate selection???
    By atomicjoe23 in forum Suspension - Wheels & Tires
    Last Post: 09-30-2009, 04:40 PM
  4. Switching from air to coil over
    By busasandrail in forum Suspension - Wheels & Tires
    Last Post: 04-01-2008, 08:12 AM
  5. Shock placement in relation to Suspension movement
    Last Post: 11-20-2006, 11:24 AM
