I just think that is what Gene and the original post was referring to..
Thread: Suspension Questions
Results 21 to 27 of 27
- Join Date
- Feb 2006
- Location
- Winder Georgia
- Posts
- 7,960
12-28-2009 10:11 PM
12-28-2009 10:12 PM
We agree to disagree then. Can't argue with sucess either way - just point out different ways to do it successfully . . .
I'll add to what Bug said in this edit - see my thread in Another Mini for my front end design by F1Prerun.
Gene
- Join Date
- Nov 2008
- Posts
- 88
01-03-2010 05:14 PM
Standfast, I hope you dont mind me using this quote of yours from another post. I was hoping you can tell me if I am understanding this right ... The spindle should be mounted as close to the centerline of the lower A arm. Or you could say the center of the wheel should be as close to the centerline of the lower arm. Am I close?
ALW
01-03-2010 07:14 PM
I think what he's saying is push the lower arm's heim as close to the tire centerline as possible. This way your spindle isn't hanging out creating a huge lever. An offset Wheel can help keep this to a minimum. With front steer and Ackerman the steering arm's heim will probably be what limits how deep you can go. In this drawing look how close the steering heim comes to the rotor.
Here's a pic. to go with the attachment
01-03-2010 07:18 PM
Good diagram RickS. Why not run the tie rod heil in the same orientation as the A-arm? Just wanna know . . .
01-03-2010 08:05 PM
On this design the heim spacers would max out going the other way. Personally I like to see them this way. It's a strong simple double shear mount on the heim.
03-29-2018 04:13 AM
RcTek - Radio Controlled Model Car Handling Main Section Page
I just bookmarked this link so I can go back and reference it. This is really helpful information since I have a number of RC cars already - Fantastic Knowledge base to build from - Thanks a ton!!!!
Racing Cost & Information for each Class.
By TutTech in forum MiniBuggy.net Lounge!Replies: 10Last Post: 08-17-2014, 10:00 PM -
By Section 8 in forum Suspension - Wheels & TiresReplies: 7Last Post: 09-01-2008, 06:49 AM -
How To Set-Up Front Suspension.. Hard & Fast Tips &
By Kawabuggy in forum Suspension - Wheels & TiresReplies: 14Last Post: 11-27-2006, 08:18 PM -
Shock placement in relation to Suspension movement
By K-fab in forum Suspension - Wheels & TiresReplies: 30Last Post: 11-20-2006, 11:24 AM -
Suspension questions
By Ecoli_happens in forum Suspension - Wheels & TiresReplies: 9Last Post: 05-18-2006, 09:17 AM
