Old 11-05-2009, 01:00 AM   #1 (permalink)
Default Front "A" arm angle
Just wondering what a good angle to have the front arms leaning back so the car rolls over the bumps best? I have 27x9x12 AMS front dune tires. I checked my wifes and my atv and they are 10*. I'm thinking that should be close.
Any suggestions?
Aleck
hookedonsand is offline   Reply With Quote
Old 11-05-2009, 01:05 AM   #2 (permalink)
Admin
Gene's Avatar
Default Re: Front "A" arm angle
You are talking about "rake'. Opinions vary and you will read them soon. the Rorty R82 has 0. My other car has 6*. I don't have enough seat time in either to compare yet I think rake is good.
Old 11-05-2009, 02:54 AM   #3 (permalink)
Super Moderator
minibajaman's Avatar
There is no right answer to this question, but I can give some background info. ATV's have 10 deg of rake because of their small tires. Larger tires need less rake since they inherently roll over bumps better. Rake tends to induce more diving under braking then without. My buggy has 10 deg of rake and uses ATV tires, and I can't directly compare it to anything but it does work well although there is some brake dive. That said, if I were to design/build another buggy, I would probably still run some rake but less, maybe 5 deg.
Old 11-05-2009, 12:10 PM   #4 (permalink)
yoshi's Avatar
Brake dive can be eliminated by raking the upper arm more than the lower, and the brake dive only comes into effect when you have front brakes...
I run 12 degrees of rake on my setup with parallel mounts.
With diagonal mounts on my first generation, I ran 15 degrees to help compensate for the forward sweep of the arms in that particular setup...
www.sinistersandsports.com
Racing Cost & Information for each Class. TutTech MiniBuggy.net Lounge! 4 10-13-2009 03:13 PM
New Front End, longer wheel base & Video of testing. TutTech Projects in Progress 5 08-17-2009 02:37 AM
Cut & replaced the front end of my brothers 9 car. Finished TutTech Projects in Progress 9 04-13-2009 02:00 PM
How To Set-Up Front Suspension.. Hard & Fast Tips & Kawabuggy Suspension - Wheels & Tires 14 11-28-2006 02:18 AM
front a arm rake Boyd Suspension - Wheels & Tires 22 07-30-2006 08:35 PM
