#11 (permalink) | |
I don't understand what you mean about torquing the axle nut enough without compressing the taper bearing. Could't you just torque it the same wat that you would on a trailer, car or truck. Enough to take out any play and still allow smooth rotation? |
#12 (permalink) |
The Drakart Formula Cross uses a Set 35 bearing. I have not had a problem with the bearings failing with jumps or wearing excessively. When I swapped out the axles and hubs, the original outer Timken bearing races stayed on the old hubs. I used the inner race out of the other side for one bearing and replaced the other side with a new bearing that was not Timken. It failed during the next race. It was not a tapered roller, but had ball in it that fell out and tore things up at the same time. I replaced that with a Timken and did not have any issue for years. I forgot to tighten a CV nut one time and the bearing came apart. Other than that, they have held up great.
#13 (permalink) | |
On the rear when conventional VW stub axles are used you put all the parts in correctly and tighten to 300 ft lbs. One bearing is a roller bearing with a sliding inner race. The spacers allow that inner race to fit inside the bearing without side load. If you don't torque it to 300 pounds the splines on the hub will fail. The hub splines are dependent on the massive torque to survive. But the good news is Doug sold you the part and he is a knowledgeable dude and can make the exact recommendation. |
| Racing Cost & Information for each Class. | TutTech | MiniBuggy.net Lounge! | 4 | 10-13-2009 04:13 PM |
| Rear Axle bearing carrier | sega702 | Driveline | 3 | 06-23-2008 12:56 AM |
| (mostly) VW bearing carrier | KaferChris | Driveline | 1 | 06-05-2007 04:39 PM |
| Bearing carrier assembly? | elvergonmexicano | Driveline | 0 | 12-07-2006 07:09 AM |
| Rear bearing carrier fabrication | Plastic Fork | Driveline | 3 | 04-01-2006 05:17 PM |
