Old 10-21-2009, 04:08 AM   #1 (permalink)
Default Simple hub question
Are hubs made to fit a specific axle, or will pretty much any hub fit any axle?
Thanks
Bump is offline   Reply With Quote
Old 10-21-2009, 05:26 AM   #2 (permalink)
Default Re: Simple hub question
From what I've seen, there are different spline counts and keyways. I have also seen tapered and keyed axles. Hope that's kinda what your asking.
kevin quesenberry is offline   Reply With Quote
Old 10-21-2009, 05:37 AM   #3 (permalink)
nutz4sand's Avatar
Yah the hub needs to match the axle. There are very few that cross over to match others with no mods.
Sand! The only gold I need!
Old 10-21-2009, 08:37 PM   #4 (permalink)
i just bought some vw rear axle stubs,and they have 12 splines,i was planing on getting my hubs from protodie,but i see the ones they have are 6 spline,does any one know where i can get 12 spline hubs,thanks
u2slow is offline   Reply With Quote
Old 10-21-2009, 09:00 PM   #5 (permalink)
nutz4sand's Avatar
Hubs to fit those... Nope no clue....
Unless they are like these?
These are the VW four bolt pattern. Any good VW shop will have them. Between 35 and 65 bucks depending on the shops markup and how pretty they are.
I think they are off the older Porsche or maybe the Ghias but do not quote me on that.
If thats what you seek print the pic out and take it to a VW shop.
Old 10-21-2009, 09:03 PM   #6 (permalink)
nutz4sand's Avatar
IF you have access to a lathe or know someone who does who owes you a favor you can also take any VW splined brake drum and machine the brake drum part off.
After market companies make all sorts of hubs for them too (some with some light weight killer brake systems) but they aint cheap.
Old 10-22-2009, 03:00 AM   #7 (permalink)
I used Nutz's idea, works great, cheap too. Doc
docteriffic is offline   Reply With Quote
Old 10-23-2009, 03:00 AM   #8 (permalink)
thanks for the help,those ideas will work great.
Old 10-23-2009, 04:50 AM   #9 (permalink)
I used turned down drums as hubs, and then non-vented rotors from a type 3 (I think) with calipers from the same. The brackets were home built, but I've seen someone sells them now. I really wanted disc brakes, and the kits were more than I had into my whole rail.
78 fl250 front shock question? outtakontroll The Pilot & Odyssey Forum 13 10-14-2009 07:13 AM
newb trailing arm question? GR8WHITE Suspension - Wheels & Tires 5 01-31-2009 06:35 AM
Quick question about trailing arms andy777bmx Suspension - Wheels & Tires 10 01-23-2009 01:32 AM
Simple question....I hope! Islander Suspension - Wheels & Tires 14 09-18-2008 10:41 PM
Snowmobile Engine\Exhaust\Chaincase Question cuda Motor - Engine 2 03-16-2008 12:50 AM
