Hello all!
Does any of you guys use full hydraulic steering on your rigs? If so, where do you bye your hardwear? And how do you drive the pump? I have an 05 busa, so if any of you have any pics of a pump mounted on this engine it whould be great! Cheers Tom |
#5 (permalink) |
bdkw1 : I was thinking about the 'Full hyrdo as in ram and servo only'.
yoshi : Thanks for the pics. How did you mount the pully on the engine side? How much power does the electric power steering give? I'm running 4wd on my rig and I guess that will need a lot more power to turn then the pure steering tyres that you use? Thanks, Tom! |
#6 (permalink) | |
Not sure on the power of the electric steering, but i've heard really good thing about this system, and don't think a 4x4 setup would cause it any issues. |
#7 (permalink) |
dont they offer that electric steering on all the new 4x4 quads?? Thats a great idea im gonna have to look into seeing if I can fit that into my budget. And im glad to see that someone is running a alternator, I was thinkin about trying it, and now Im gonna do it!
#8 (permalink) |
My brother's V8 pulling tractor is fully hydraulic steering with hoses only going from the column to a cylinder at the wheels. Since the steering wheel is about a foot behind the distributor, it is difficult to run shafts. The steering is off a commercial lawn mower. He had another one from a fork lift and one from a boat that did not provide the ratio he wanted. It leaks a little internally so it is good he used a splined quick disconnect on the wheel. The wheel ends up needing to be turned a spline or two after each time he drives it.
#9 (permalink) | |
For the pump drive off the motor you will need something like Yoshi had. |
#10 (permalink) |
I have been running EPS for a decent amount of time now. Probably 2 to 3 thousand hard miles on a desert car. I like it. I would not use it on a 4wd buggy that will be used like a rock crawler. Full hydro in a light car like that is probably overkill. Now if you are gonna use it like a SXS or something like that it should be fine. (they already have kits for them)
| air- hydraulic set up for bender | ProtoDie | Shop Talk | 28 | 11-26-2009 02:47 PM |
| Will this steering work? (Bump steering?) | RD350LC | Controls and electrical | 8 | 06-15-2009 12:26 AM |
| Steering stops? | robndeb | Controls and electrical | 18 | 12-20-2008 10:54 PM |
| home made build | 50nuts | Projects in Progress | 56 | 03-25-2008 11:31 PM |
| 05' Honda trx450r "full race" | Chase044 | For Sale | 12 | 01-16-2008 09:57 PM |
