Old 06-16-2009, 08:34 AM   #1 (permalink)
Default spindle design
hi im looking at building my spindles with a horizontal bot in the bottom to mount a 3/4 rodend in double shear is a 3/4 rodend with a vertical mounting bolt in single shear strong enough .Hope too have a finished weight around 1000 lb.
blaster is offline   Reply With Quote
Old 06-16-2009, 12:57 PM   #2 (permalink)
millfab313's Avatar
Default Re: spindle design
any pics to get an idea of what your putting it on? and how they will be used?
millfab313 is offline   Reply With Quote
Old 06-16-2009, 01:09 PM   #3 (permalink)
Administrator
K-fab's Avatar
Yes, please break out Paint and draw what you're trying to explain.
I think I follow, but I'm not quite sure.
For the main heim (rod end) - lower arm/mounting point for the spindle - a 3/4" size should work.
Old 06-16-2009, 01:45 PM   #4 (permalink)
Ill give it a whirl with my new found skills...
Old 06-16-2009, 05:18 PM   #5 (permalink)
typically the upper joint sees much less force than the lower. Depending on the geometry it could be less than half. Also having the lower bolt horizontal loads the lower spehrical radially (strong) instead of axially (weak) there are axial loads on the lower but I think the radial load is much higher. Then on the upper joint there are really only cornering and brakeing forces. the cornering forces will not matter as far as your orientation of the spehrical but with the bolt being vertical on the upper rod end it will transfer the brakeing forces to your rod end radially instead of axially, which is good. basically I think your design is pretty efficient. Dont hang the single shear upper joint way out, the closer you can get it to the structural part of your spindle the better, and make sure your lower joint can take your steering angle without binding.
Damien is offline   Reply With Quote
Old 06-16-2009, 06:29 PM   #6 (permalink)
millfab313's Avatar
a simple way too is to get some yamaha spindle off a four wheeler cheap and proven designs and they hold up really well, unless you just want to make them for the sake of saying i did that. thats cool too.
Old 06-16-2009, 06:51 PM   #7 (permalink)
Simple way is to cad up some boxed uprights and have them waterjet and weld them together....
Old 06-16-2009, 08:35 PM   #8 (permalink)
Admin
Gene's Avatar
What software are you using Bug? New skills are good!
Old 06-16-2009, 08:51 PM   #9 (permalink)
Sorry, the 3d is from Kwicksand, the 2d drawing is Acad... I am getting very good in a cad i have been at it about 3 weeks or so...
Old 06-16-2009, 08:56 PM   #10 (permalink)
Admin
Gene's Avatar
Man, that's a name from way back! Last I talked to Kent he was in Idaho. i should email him and see what's up.
Thanks!
spindle pro's and con's? yoshi Suspension - Wheels & Tires 112 10-27-2009 03:49 AM
Tire Sizes & Squish for design Engineer Suspension - Wheels & Tires 15 10-21-2008 08:34 PM
Spindle Plans MrDiesel The Drawing Room 5 02-06-2008 12:04 PM
Alibre Design 8.0 Training Videos hero_saku39 For Sale 2 12-20-2007 12:59 AM
Judge this design MXman Frame 15 11-08-2006 06:35 AM
