I need some help. My team and I are building a sae baja car. We're using 2007 Polaris Predator ball joints. They're too short to have proper camber and thread left through the mount. Anyone know of a ball joint assembly that has the same thread as the Polaris ones but are longer. We need like a .3-.5 of an inch.
Welcome to the site! Could you post a picture of your current setup? That would help me better understand what exactly the issue is. There is not enough thread to go through the a-arm mount or the spindle mount? And how does camber affect that?
#4 (permalink) |
Another option might be to weld on a plug extension to the a-arm, and drill out the current one a little to allow the thread to pass through. Just make sure you have enough threads to grab the ball joint.
| fixed joint 930 cv's | krazee | MiniBuggy.net Lounge! | 10 | 09-08-2009 09:05 PM |
| 930 CV Joint | Sheldonjay | Suspension - Wheels & Tires | 8 | 10-24-2008 04:30 PM |
| Wheel bearings...taper roller vs ball bearings | PANZER | Suspension - Wheels & Tires | 18 | 11-28-2006 02:47 AM |
| CV ball bearing? | Mike | Suspension - Wheels & Tires | 1 | 11-17-2006 05:05 AM |
| Heim joint questions | Mike | Suspension - Wheels & Tires | 14 | 11-07-2006 09:27 PM |
