i am new to this. i just turned 18. i am a vary good welder i can tig. i can use a cnc/ macheine shop and have access to all of the equipment needed. i know how to build a center carrer. but i cant for the life of me lay out a way to make outer hubs with the bearing. i would like to build a one seater based off the panther mini rail with plans i caded/ drawn my self. i want to use like a 750 to 1000 street bike engine. also i would like to use quad parts i am smart but have no real exsperence with cv's and bug parts the only irs set ups i have mesed with are quad and datsun 280z irs. thank much prase will be gave. i turn 18 on saterday hell yeah
#8 (permalink) |
i would like to a-arms front and rear. i don't like the stress on the bearing from trailing arms. i think what i will do is have a friend custom machine me some bearing holders from steel or aluminum. sometimes you can find a could chunk for cheep.and and then put some 1 inch o.d quad axles cut with some custom 930 CV adapters on them then just build it in to the system.
go busa or go home |
#9 (permalink) |
well here is an idea you dont have to build them i found a guy on ebay that will send me a cut /
he cuts the bub out of vw swing arms bearings and all they are sweet a little trimming to get rid of excess metal whats left is a round tube/hub it bolts together its premachined and you can buy stubs that have 930 flanges premade on them i am using them on my build now here is an economy idea i also saw ......a disk brake conversion setup on you guessed it ebay for $179.00 it bolts right to that hub the rotor has a four bolt pattern all of the work is done for you jmo tell me what you think dont be shy lol Last edited by magnum4598; 03-08-2009 at 04:05 AM. Reason: bad typing lol |
| Tags |
| axle, drive |
| F150 Outer Bearing Hubs and CV's | standfast | Driveline | 87 | 06-22-2009 05:14 AM |
| Rear axle hubs - help | Radical Rob | Suspension - Wheels & Tires | 8 | 01-31-2009 08:52 PM |
| Axles and wheel hubs for someone's projects | LiveWire | For Sale | 0 | 04-19-2008 01:02 PM |
| Will these wheels work with these hubs? | P-Dog | Suspension - Wheels & Tires | 9 | 01-24-2008 03:56 AM |
| Front Hubs and Axle Kits | K-fab | For Sale | 5 | 01-18-2008 04:12 AM |
