Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
    Re: St4 build 23/8/2016
    Started working on the buggy again for about a week now I started the back end of the chassi and fabrication of the front a arms.Got most of the bushings and tubes needed for the front a arms done. I couldn't find any of the rectangular tube needed for the a arms so i decided to make it using two pieces of angle bar welded together. I don't have a tubing bender i'm just cutting the angles and welding the tubes together. Also got a big new drill press.
    Hi guys do you think these heims are good enough for the front suspension or should i get something heavier duty
    https://secure.chassisshop.com/partdetail/CM10/
    Sep 2008
    Allendale MI
    IMO, I think you are good with those. Just use a hi-mis spacer and you will have a 1/2" bolt going through the assembly. Maybe use 3/4" heim joints out at the upright connection and use the 5/8" joints at the chassis connection.
    Justin
    Nowhere near the desert.
    I'm using bushings at the buggy end of the suspension as that's what the plan called for. Thanks for the info.
    I have some more progress pics
    May 2015
    Lithuania
    Hi, what kind of machine is used for welding? weld looks very bad
    Doesn't look like any surface prep was done. All welded areas need to be taken down to bare metal before you start sticking them together.
    A sander or even better one of the 525 Industries tube prep tools does a fantastic job. You have to get down past the protective coating on the tubing.
    Ya I had to paint the chassi when i stopped working on it as it had to be stored outside for a while. The welds are just tacks. I use a wire brush on an angle grinder to sand it down before welding. Its a pain in the ass but has to be done
    Sep 2008
    Allendale MI
    I've always been a fan of how the back of those cars look. I agree with the above. Wire wheel those joints for sure. Oh yeah, hold on tight to that grinder with a wheel. LOL Been there.
    Justin
    Justin
    Lol.I hate when the wires on the wheel come off hurts like a bitch.Yeah I really like it to specially when there is a spare tire on there
  1. Youth Rally at Doe Mountain coming June 2016.
    By RacingDreamz in forum Events and Group Gatherings
    Last Post: 04-15-2016, 10:14 PM
  2. 2016
    By Fabdoc in forum MiniBuggy.net Lounge!
    Last Post: 01-03-2016, 12:11 AM
  3. 2016 Honda Pioneer 1000!
    Last Post: 07-29-2015, 03:53 PM
  4. 2016 SVT Bronco
    Last Post: 04-02-2014, 06:41 PM
