Results 1 to 9 of 9
    Thottle pedal cable attachment
    Hey guys and gals,
    I'm trying to attach my throttle cable to my ST4 designed foot pedal. I cant really think of a good way to safely attach the cable and still get enough stroke for WOT. I also dont like how high up the pedal is in relation to the frame. It makes it such that the cable will have to run higher and then its kinda in the way of my foot/leg. So I'm thinking to attach on some bar or extra piece that extends down towards the floor board so that I can attach my cable to it and keep it better protected.
    Thoughts? Pictures of your setup?
    thank you
    Re: Thottle pedal cable attachment
    The higher up on the pedal, away from the pivot point of the pedal, the more cable pull you'll have and the more throttle control you'll have.
    Do you happen to have any pix of what you're talking about?
    Edit - oops, I'm thinking backwards. Lower down gives more pedal throw relative to throttle pull.
    Sorry about that.
    Senior Member sotiris's Avatar
    May 2015
    greece
    Quote Originally Posted by sotiris View Post
    This second pic is perfect. What is that piece that the cable goes into? The brass looking piece/assembly. Was that purchased and can you point me in the direction to find it?
    thank you!
    I did what your talking about on mine. Lower give me more pedal travel, which I like very much.
    May 2015
    greece
    Quote Originally Posted by offroad_buggy85 View Post
    thank you!
    You can find parts to bicycles store or to a motorcycle service store
    I used the bolt with hole in it from bike store. They gave it to me.
    Great thank you for the feedback, ill head to my local bike shop after work today.
    thanks
    Senior Member Beruba's Avatar
    Feb 2014
    Alberta Canada
    I use the shifter linkage from the motorcycle and a wire clip it works good.
  1. File Attachment Upgrades have been implemented
    By K-fab in forum Minibuggy.net News
    Last Post: 10-02-2014, 04:48 PM
  2. Good throttle pedal cable connector
    By jjstime in forum Controls and electrical
    Last Post: 01-12-2013, 11:14 AM
  3. Rear sprocket attachment to irs
    By allenmike in forum Driveline
    Last Post: 09-03-2012, 11:05 PM
  4. Designing Sand Rail Frame attachment for Water use
    By DigiWolf in forum Projects in Progress
    Last Post: 07-07-2012, 02:41 PM
  5. CBR1000rr/roller pedal throttle cable
    By pat656 in forum Motor - Engine
    Last Post: 10-17-2011, 03:46 PM
