Results 1 to 10 of 38
    ST 2 Long Travel Buggy
    Hello , been lurking around here looking and reserching as much as possible . So jumped in to the buggy building .And I bought the plans to start my ST2 , but I guess it's my fault . I didn't realize that it was made from 1 inch tubing . I was wondering does everybody always stay with 1 inch or go up to say 1 1/4 or 1 1/2 . My plans was to run a 600 cc bike motor or if I could find one maybe a 750 . Any thoughts ?
    Re: ST 2 Long Travel Buggy
    bigger is better im running (not actually running yet lol)1000 but my buggy is also 4x4
    Jan 2009
    The 1" tubing is 38mm in diameter... not 25,4.
    For the ST2, 1" is working fine! It's quite a compact buggy and bigger size tubing is harder to work with in this design.
    Jul 2011
    Larnaca, Cyprus
    Bigger is always better.. I have a 750cc in my 2 seater modified st3 and am pleased with it.
    For an st2 750cc should be good.. but bigger is better, and you will always want more power
    My plan is to trail ride and to play in the sand with it . But with the extra size does anybody have any idea how much more the buggy going to weigh -in at with the larger tube ? Because weight is power.
    Jul 2009
    Fort Worth Texas
    forget how much it weighs...build it strong. Thick wall tube. I went the cheap route and paid the price.
    Trust me.
    Glock n Ballz
    Ft. Worth, Tx
    Thought I remembered the Badland plans called it "pipe" which would have an ID of 1" and OD in the 1.25-1.35" A build out of 1.25 "tube" would be stronger and lighter. .095 wall. 1" tube for some bracing would be fine.
    Trust me.
    Glock n Ballz
    Ft. Worth, Tx
    What do you mean ? Please explain .
    As far as the plans calling for the use of pipe I'm going with DOM tubing . Not sure if I going with .083 or .095 wall thickness .
    I would go with .095 dont mess with safety
    Yea , My thoughts exactly , 1 1/4 Dom tubing an .095 walls thickness . And leave the bottom 1 1/2 Square tubing . and see how that holds up . Does anybody run 1 1/4 tubing on there A arms or leave it 1 inch heavy tubing ?
  1. Long Travel Suspension Design
    By DieselTwitch in forum Suspension - Wheels & Tires
    Last Post: 12-25-2012, 02:39 PM
  2. R1 Long Travel Rail
    By clayh88 in forum For Sale
    Last Post: 08-13-2012, 04:39 PM
  3. improving the turning of an ATVR long travel Pilot
    By odypilots in forum Honda's Pilot & Odyssey
    Last Post: 04-25-2011, 04:06 PM
  4. Badland Buggy ST2 Long Travel Suspension brain storming.
    By Glock n Ballz in forum Suspension - Wheels & Tires
    Last Post: 02-15-2010, 03:07 PM
  5. 05 Rhino with Long Travel, Cage, Paint, etc. $11,000.00 *****
    By PlaySomeSkynyrdMan in forum The UTV Area
    Last Post: 08-13-2009, 04:58 PM
