Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    Badland ST2 custom build from Ireland
    May 2013
    Cootehill ireland
    Hi all
    My names Kevin I'm 39 mechanic by trade but work in engineering for the last 20 years cars are more a hobby now than anything else
    I've had ideas of building a buggy for years now and there was always something more important financially and otherwise ,I've been gathering parts for years as I suspect most of you do
    I purchased a 750 gsxr k5 powerplant around 6 years go with just 300 miles on it
    Wheels and rims followed soon after
    Bucket seat and loads of other useful stuff
    I had it in mind to buy plans from edge products but one day recently I found a video from another member here on YouTube about there build and having never heard of an st2 a google search ensued
    I liked what I saw and bought the plans for a long travel st2 though mine may end up buying more of a medium travel buggy
    Bought piping and invested in a pipe bender and off we go
    Once. All the plans were transferred to my jig board things progressed nicely
    Time for me at this is always gonna be an issue I work six days most weeks
    Day one saw me this far
    Day two was a lot shorter and involved allot of head scratching I didn't like the box section used in he plans to make the base of the frame it seems to me a little agricultural so I decided to go with a full tube frame this straying away from the. Plan hasn't caused me much issue so far
    This pic shows the tubular base with engine and. Things fitted for guide only
    Rear drive train is going to have a limited slip diff I made up from a impreza wrx rear LSD
    It was incorporated into the original wishbone mounts from the badland plans and will have twin in board disc brakes when complete I'm using the std r160 shafts and cut down rear impreza hubs too
    This is why I may end up loosing some suspension travel I'm unsure as yet how much angle these drives can take but I'm hoping around 14 " + or --
    Tonight I got about 4 hours at it it's now 1.40 am here and I'm not long up from the garage
    After 2 mates passed comment that my buggy was very long I decided tonight to take 9 inches off the overall length before I did anything else structural it was also in my head that it was big but my friends confirmed it for me. Luckily it was an easy task as its only tacked together as yet.
    Also added a few more bars from the original layout I think it looks better now that its shorter
    I will have to rework my steering angles now I reckon and hope this decrease in overall length won't have any ill effects
    That's it for now
    More updates will follow as this buggy owes its origins to Erwin from the Netherlands if I hadn't seen his video I'd be building something different
    Re: Badland ST2 custom build from Ireland
    Senior Member Duane's Avatar
    Apr 2010
    Santa Rosa California
    I do like your skills and willingness to change things to suit your whims. The frame looks good. What is the specs on the tube you are using? I want to see your bender also. Keep those pictures coming.
    May 2013
    Battle Ground, WA
    I would really like to see your bender. My tube flattens out.
    Are you using tube or pipe?
    Trying to find time to finish that buggy...
    May 2013
    Cootehill ireland
    I'm using pipe what we call gun barell over here it has a 2.5 mm wall mild steel with a welded seam all the way on the inside
    That is what the specs call for on the badlands buggy plans
    I had seamless tubing bought but the dies / guides on my bender dont fit it perfectly so it does tend to flatten a bit
    My bender is a hyd 15 ton capacity sealy brand it will bend from 1/2 " to 3" pipe
    I'm quite happy with it easy used and cost me 500€ about 750 dollars
    Probably expensive if you only want to build one buggy but I will use it on other builds and make the odd piece of farm machinery too
    Will take another pic of it tonight and post it here
    May 2013
    Cootehill ireland
    Also went shopping today and bought a small single phase Harrison lathe
    It's old but its all good
    Senior Member monkeyinfantry's Avatar
    Sep 2012
    Howell, MI
    If i'm not mistaken, you're not supposed to use pipe because its designed to hold pressure in and carry liquids, not hold up to physical hits, aka, it will fold like a paperclip in an accident
    My Protodie SS1000 Build
    My 1980 SR250 Build
    My 1999 Blaster Build
    2016 YZ450F
    2006 YZ450F
    2013 KLX110 stockmod
    May 2013
    Cootehill ireland
    Plan says use it so I used it mild steel is what it recommends
    It specifically say don't use high carbon as it will snap and scuere you like a sausage in an accident I'd rather have a bent buggy that be stabbed by a wishbone or cage bar
    This is an amature build I'm not a pro welder qualified to weld special metals
    In the short lengths between braces it will be fine
    You got one of them backwards lathes!
    Just kidding.In the US the compound and carriage handles are opposite.Boy is it hard to switch after using one or the other for a long time.
    Nice lathe.
    Sep 2012
    Howell, MI
    Ok well if the plans say use mild steel pipe then I guess you can, I've just always heard to use mild steel DOM tube and nothing less. Just lookin out for your safety! Buggy looks good
    My 1980 SR250 Build
    2016 YZ450F
    2006 YZ450F
    May 2013
    Cootehill ireland
    I'd love to use something lighter and stronger and less of it but on my first build at least I'm going to stick with this
  1. ST4 build - new to minibuggy
    By Benjammin1414 in forum ST4
    Last Post: 01-09-2014, 05:21 AM
  2. new 4 seater build project---need ideas on engine n trans to use
    Last Post: 01-08-2013, 09:24 AM
  3. Ready to start a build
    By Snoopy in forum MiniBuggy.net Lounge!
    Last Post: 07-26-2012, 05:29 AM
  4. Custom Buggy Build
    By Eoxan in forum Projects in Progress
    Last Post: 05-19-2012, 12:56 PM
  5. Love for the Build
    By AtvNut in forum How To Do It
    Last Post: 10-04-2010, 07:52 AM
