Page 27 of 27 FirstFirst ... 17 25 26 27
Results 261 to 268 of 268
    Re: Basic Protolite SS1000 Frame Build
    Jan 2014
    5 Min from the dunes!
    Sweet! We hadn't heard from you for a while and I hoped that you had finished it. Very cool so see someone from where I grew up on here too.
    -Fl350 resto mod-
    -Wind turbine electrician-
    Senior Member bryzoe's Avatar
    Dec 2013
    Centralia, Wa
    Quote Originally Posted by Bansheebrigade View Post
    Thanks, sort of put the buggy on the back burner, now with Winchester Bay dune trip coming up i'm trying to dial things in.
    Dec 2013
    Centralia, Wa
    Thanks Plkracer & Beruba, I think I'm going to just buy whatever # shim stacks I decide on. I found out my valving is is 40/90... which is horrible as far as body roll.
    Jody, would you care to comment on your recommended shock valving set up of 90/110 ?
    Thanks
    Dec 2013
    Centralia, Wa
    Dune trip coming up mid July. Im currently running itp sandstars with 7" wide rims... kind of narrow.
    I was wondering if I can run a 12x10 4+6 offset rim (Douglas wheel Red Label) and a 13" wide dwt doonz Paddle on the protodie rear wheel kit without any interference?
    There is also a 12x8 rim available but would rather go with the 10" width.
    any input would be appreciated thanks.
    <a href="https://youtu.be/6zxUHezp60Y" target="_blank">
    https://youtu.be/3XtHn6iuvC8
    S.W. Michigan
    Quote Originally Posted by bryzoe View Post
    Thanks
    sorry for the delay, just came across this.
    90/110 is what we found worked well for us after much testing years ago.
    we jumped, videoed, reviewed, re-shimmed repeat,,,repeat,,,repeat,,,repeat and this is what we found we liked.
    not saying its perfect, but for us , much better than factory
    to reduce body roll, max out your shock oil levels, cheap and easy and we found it improved the shocks a lot for our application.
    we experimented with how many cc's of oil to add, then found that the amount of oil varied from the fox factory
    so then we would take the nitro out of the shocks , jack it up and let them droop ,,,, add 100 to 150cc s of shock oil to the shock
    slowly lower it to full bump to push out excess oil and then take a veterinary syringe from the farm store and suck out 5-10 more cc's of oil.
    this reduced our nitro pressures and stabilized the sir shocks much more than from the factory
    Dec 2013
    Centralia, Wa
    Thanks for responding Jody,
    I tride the 90/110 shock shim stack and it worked perfectly for the dunes, worlds apart from the stock valving. I was curious about oil volumes and will try your recommendation. I am totally thankful for your extensive testing!
    I also noticed in some pictures of your red ss 1000 that your were running the DWT Doonz paddle tire, do you remember the rim size?. I really want to run a 10 inch rim but am concerned about the 4x6 offset interfering with the rear wheel kit and suspension.
    S.W. Michigan
    these are the wheels I ran
    DWT 12" Spun Wheels for Doonz Tires
    Spun 12x10 4B+6N 4/110 Rhino
    with these tires
    DWT Doonz Sand Tire
    25.5x13-12 HD 6PR Rear
    Dec 2013
    Centralia, Wa
    Great, Thanks Jody!
  1. Rorty R82s (Bikelomens build) and R16 roller frame
    By Montanaminirail in forum For Sale
    Last Post: 11-11-2013, 02:07 PM
  2. Replies: 110
    Last Post: 07-10-2013, 08:10 PM
  3. Plans for 2 seat buggy _Protolite SS1000
    By ProtoDie in forum MiniBuggy.net Lounge!
    Last Post: 12-11-2012, 10:49 PM
  4. Hotwheels000 rebuild
    By hotwheels000 in forum Projects in Progress
    Last Post: 01-30-2007, 03:07 AM
  5. Replies: 11
    Last Post: 01-16-2007, 12:03 PM
