Page 11 of 11 FirstFirst ... 9 10 11
Results 101 to 106 of 106
    Re: My Protodie build
    Hmmmm ok, doesnt seem like midwestcontrol sells pull only cables, even custom, I'll look into the site you recommended
    Edit: You sure I shouldn't use a push-pull? I see multiple buggy sites listing push-pull cables as throttle cables...
    Kartek
    Moore Parts
    Many other sites selling these too, and I can't for the life of me find anyone selling pull only throttle cables that aren't custom to order. This doesn't seem as straight forward as it should be haha
    My Protodie SS1000 Build
    My 1980 SR250 Build
    My 1999 Blaster Build
    2016 YZ450F
    2006 YZ450F
    2013 KLX110 stockmod
    Sep 2008
    Allendale MI
    My guess is that the cables you see at Kartek, Pacific Customs, and EMPI are more geared for the VW and automotive applications maybe? My only logical thought is that the bikes originally had cables, so i went that direction.
    Justin
    Nowhere near the desert.
    I used a stock atv cable, just happened to have right barrel and adj part fit my zx12. It runs over and down between seats. Then a standard braided cable is attached runs straight to pedal. There is a company that makes custom length cable with correct fitting on ea end, as some friends got em on their m/c cars.
    Ok thats what I was figuring, VW buggys and not sand rails. I have both stock throttle cables, they're really short though, probably not long enough to even reach the floor so I'll have to order me up a custom one. Thanks guys.
    My 1980 SR250 Build
    2016 YZ450F
    2006 YZ450F
    S.W. Michigan
    here is a link to what I use in our SS buggies
    http://protodie.com/Throttle-Cable_p_170.html
    I just noticed the category has been hidden on the website and fixed that
    on the GSXR motors:
    I drill the stock throttle body hole slightly bigger to fit the brass barrel on the throttle cable, then the double nut on the threaded end of the cable locks right in to the throttle body mount where the stock cable was.
    I also add a return assist spring
    on the gas pedal end of the cable, I weld a tab with a hole to the frame to position the cable where I want it,,, in relationship to the gas pedal
    then I drill a small hole sideways thru a 5/16 or 3/8 bolt. I put this bolt thru the side of the gas pedal plate at a height to match pedal and throttle body throw
    then put the cable thru the side ways hole in the bolt and use 2 jam nuts to pinch the cable tight
    hope this helps
    Cool, much easier, thanks Jody
    My 1980 SR250 Build
    2016 YZ450F
    2006 YZ450F
  1. Two seater mini buggy build, side by side
    By PeteNado in forum Projects in Progress
    Last Post: 08-29-2014, 03:39 AM
  2. Protodie Build
    By Croush20 in forum SS1000 - Two Seat Race Buggy
    Last Post: 06-03-2013, 11:28 AM
  3. Amer's ST4 build
  4. new 4 seater build project---need ideas on engine n trans to use
    Last Post: 01-08-2013, 08:24 AM
  5. My first build
