Page 3 of 13 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 129
    Re: Shredder 2 build
    #21
    Purchased a plasma today. Hypertherm 30xp. Wish I had bought it much sooner.
    #22
    Starting the mounting brakets for the hubs.
    #23
    Aug 2014
    SLC Utah
    Looking Good!!!
    #24
    Senior Member Jerm's Avatar
    Dec 2013
    Ontario Canada
    I did the exact same thing with my trailing arms, had those 2 plates lazer cut at a local shop. That middle hole looks big tho? Could it be smaller or were you limited to certain bits/tools?
    #25
    #26
    The hole is a little big because of the hole saw I was limited to. Don't think it will make a difference. I bought a plasma the next day.
    #27
    All this sprocket and chain info is confusing. Let's say I use a Comet Duster torque converter. The driven pulley has a 1" diameter hole. So I need a 1" shaft to go through that and have my small sprocket on that shaft correct? Let's say I am going to use 12t and 60t sprockets. I cannot find a 12t and a 60t to fit the 1" shaft with the same chain pitch.
    #28
    Jan 2012
    SLC, UT
    Make a flange that is attached to your axle, then bolt up your sprocket to that.
    I welded my flange directly to my axle and it works great.
    #29
    Thank you for replying. That's probably what I'll do. I'm trying a contact at a local atv repair shop next week for Polaris atv clutch and gearbox.
    #30
    Dec 2013
    Ontario Canada
    Cool I'd really like to see it happen in a shredder. I Had plans to do the same, but those plans changed when a sled became available, the only issue I can see is that you need to get the gearbox quite close to the engine because of belt lengths, That can be tricky if the engine is a V-twin. Look at getting the gearbox from an older unit, its much smaller and compact.
    Also check ebay for the polaris clutch and gearbox, sometimes they go for around $100 each.
  1. Two seater mini buggy build, side by side
    By PeteNado in forum Projects in Progress
    Last Post: 08-29-2014, 03:39 AM
  2. Amer's ST4 build
  3. new 4 seater build project---need ideas on engine n trans to use
    Last Post: 01-08-2013, 08:24 AM
  4. Shredder 2 build
    By ironworkerlocal9 in forum Projects in Progress
    Last Post: 12-22-2010, 05:10 AM
  5. My first build
