#84 (permalink) |
It's close. The measurements are all fine and no tool crashes which is always good. The surface finish wasn't as fine as I would want so I am going to reprogram the finish passes with smaller steps and stepovers. I am still thinking maybe it would be best to cut it on the VMC leaving 0.010 or so on everything but the holes and bores, then you could make a finish pass with a lathe to get it just the way you want it. We'll see. If I have time I'll recut the prototype tomorrow with a finer finish. Now that I've proofed the program to make sure that there are no crashes I can crank it up and let it rip so rerunning it won't take much time.
#86 (permalink) |
Nope. That was just a proofing run to make sure I didn't have any mistakes or crashes. Even though programs check out OK when I verify them in CAM I have made it a habit to run them the first time on the machine at about 15% to proof a new program. Now that I am sure that I am clear I will pour the coals to it. And yes I am quite happy with the little Haas. It does everything I need.
#87 (permalink) |
So do you have an address I can send this 50lb chunk of steel to? Also, I am sticking with the S-10 setup after I weighed the pros and cons and the cost and labor involved so there aren't any changes to be made on what you have done. I also like the idea of leaving .001 extra on there to be final cut on a lathe
