Results 11 to 20 of 25
    Re: Turbo Hayabusa Buggy Suspension issues
    Just from vid looks like rebound is slow, comp high causing it to pack and pogo. Front didn't look too bad, I'd only play with rear, getting it closer will help front too. But I'm no coilover guru, but spring rate don't sound far off.
    Sep 2008
    Allendale MI
    Here is a cool video on spring calculation. I'm pretty much stupid, so this was the only way I could wrap my head around the whole spring-rate. If this was a VHS tape it would be worn out. LOL
    https://www.youtube.com/watch?v=4FZp_oDGQNY
    https://www.youtube.com/watch?v=NLhqHPILqn0
    Way cool ways to determine spring rates regardless of suspension design.
    Justin
    Nowhere near the desert.
    Both of those videos are geared to the rock crawling crowd. Set your minibuggy up like that and it will be way to soft.
    All that frequency talk is a snow job. Frequency matters in valve springs, not coilovers.
    Unsprung weight and sag #'s are all that you need.
    Whoa, Desert rides flashback.
    Also, that diagram will do nothing for you. It is for a solid axle with a 3/4 link. Your IRS will not react at all like that. Not even a little.
    Sounds like a conversation I had with Flyer recently - he kept going on and on about squat and anti-squat and then someone said "it's for solid rear ends" and we threw it all out the door.
    I've heard the same thing about the frequency thing too - not a real world app for our suspensions. Good to see both of these comments from our local Wizard.
    Sep 2008
    Allendale MI
    Very true, the frequency talk didn't sink in very far and I threw that out.
    Justin
    You can apply the anti-squat to an IRS if you have castor angle built in, the only mass produced example off the top of my head would be on a Polaris outlaw 525 IRS, the rear arms are angled 10 degrees or so - when the tire pushes against the ground to go forward, the reactive force pulls the suspension arm down slightly (maybe not more than the weight transfer of the ATV/rider put on the suspension, but it would act as an anti squat). A solid rear axle that's driveshaft driven has a reactive force about ring/pinion gear that adds to the antisquat relation, while a chain driven axle this force is countered by the tension on the chain.
    Jan 2015
    Norco, CA
    Hey FNS, are you going to Glamis for new years?
    PS,
    I could also use some help from the suspension genius
    Vendor yoshi's Avatar
    Sep 2005
    Broken Arrow Oklahoma
    The suspension is packing up really bad. Run the video in slow mo at the 1:31 mark (on youtube hit the space bar fast to pause un-pause). The rear wheels are not coming down fast enough so i'm another vote to look at rebound......
    www.SinisterSandSports.com
    918-521-3736
    May 2013
    Easton, PA
    yep, that's about the best spot in the video to see them hanging in air. watching him go up the first time reminds me of my rough hill climb issues with anti-squat, (hoppity hop under accel) but worlds apart design wise. that side view shows it's all kicking up fast (comp maybe too soft) and not coming down quick enough (rebound shims too stiff) gas pressure could be part of it as well.
    Senior Member fns's Avatar
    Apr 2012
    phoenix az
    Everyone that posted thank you for the all the feed back. We soften everything up and took it back out 2 weeks ago. https://www.youtube.com/watch?v=X5Ao...ature=youtu.be
    It is better but still not right. You can see in the slow motion that the front end is not really even moving.....Changed out all the springs and re-valved it. I am headed out to the dunes tomorrow to test it again. I will post up more videos after this next week ends trip.
    PS KUMA....Yes I will be going to the dunes over new years. I pretty sure we are going to stay at gordons.
  1. Turbo Hayabusa
    By trailrider43 in forum For Sale
    Last Post: 02-26-2016, 12:29 PM
  2. Turbo hayabusa buggy down sand highway
    By fns in forum Show off your toys in here!
    Last Post: 11-21-2012, 11:40 AM
  3. Hayabusa spark issues, please help!
    By Nsparker in forum Controls and electrical
    Last Post: 11-11-2012, 10:02 PM
  4. turbo hayabusa
    By Jetboy_05 in forum Motor - Engine
    Last Post: 08-16-2011, 12:28 PM
  5. Hayabusa: NA or Turbo
    By 1993KA24DET in forum Motor - Engine
    Last Post: 01-31-2011, 09:20 AM
