Show off your toys in here! Wanna show off your new off-road buggy? Pictures and videos? This is the place!
Old 08-29-2009, 02:37 AM   #11 (permalink)
Default Re: First Buggy, KZ1000 Engine
These photos are of the steering. I think the geometry is off but maybe my imagination or optical illusion.
I installed limit tabs to keep the wheels from going too far and making contact with the frame. The view of the steering pointing straight is with the steering box in the center of it's travel.
If anyone has any opinions of this I would appreciate it.
Budman56: I machined the center and outer bearing carriers as be the Desert Kart plans. The center took two attempts.
mikefayetteville is offline   Reply With Quote
Old 08-29-2009, 02:40 AM   #12 (permalink)
Here are the steering pics.
Old 08-29-2009, 03:12 AM   #13 (permalink)
nutz4sand's Avatar
Can you get a well lit shot of the front uprights where the front suspension arms hooks to the chassis. Striaght from the front at close to the same level they are? Looking for the angle of them from the bottom to the top. Trying to see both at once if possible.
I also see an issue with the steering box location I beleive but want to see what others say. Could be forward a bit more.
Sand! The only gold I need!
Old 08-29-2009, 03:13 AM   #14 (permalink)
nutz4sand's Avatar
I will also add that where the steering rod hooks to the spindle could be out towards the rim a little bit more.
Old 08-29-2009, 03:23 AM   #15 (permalink)
El Toro's Avatar
Looks like fun Welcome...
"Be just as enthusiastic about the success of others as you are about your own"
El Toro is offline   Reply With Quote
Old 08-30-2009, 12:24 AM   #16 (permalink)
you might find yourself bending tie rods, being how skinny they are.
voodoochikin04 is offline   Reply With Quote
Old 09-07-2009, 02:24 AM   #17 (permalink)
Nutz4sand, Here are the pics from the front showing the angle of A arm connection points.
The pic is off to the right a little. The angle on the two up rights on each side have the same degree. The only thing I can think of is the way the frame narrows and the rear A arm upright is at a wider point than the front. This would make the A arm point forward the same amount instead of being perpendicular to the frame.
Maybe I am looking into this issue too much and the steering is working as designed.
Thanks for the replies and suggestions.
Old 09-07-2009, 08:02 AM   #18 (permalink)
I built one and it looks like the upper A arms are to long and the steering box is to low and needs to be forward. Mine mite looks all most the same way in this pic because of the angel, but you can tell that the upper is shorter than the lower. Mine steers perfect.
Gotted is offline   Reply With Quote
Old 09-07-2009, 03:27 PM   #19 (permalink)
nutz4sand's Avatar
Both pics are a little dark. Gotteds is a little easier to see. But even his pic is a tad dark out at the wheels.
Mike yours looks like its got the kinpin angle backwards. I can see the hiems. But the overall pic is just to dark for me. Better flash or a big light or outside in daylight maybe?
Need engine suggestions for a 4x4 buggy UkraineTrain Motor - Engine 6 07-30-2009 06:34 AM
JetSki Engine in a buggy? (oops gotta be PC here PWC...) PilotHawK Motor - Engine 7 08-19-2007 05:47 PM
RM 250 engine in single seat buggy stamp4 Motor - Engine 27 01-13-2007 03:05 PM
GSXR Engine drivetrain, will it last in a buggy minirailguy Driveline 12 01-11-2007 10:45 PM
type III VW engine in buggy? Bedo MiniBuggy.net Lounge! 7 11-28-2006 11:51 PM
