SAE Baja SAE Baja Projects and Teams forum. If your school would like a dedicated private forum for your team, contact an MBN staff member.
Old 07-12-2012, 02:48 PM   #1 (permalink)
Default engine control unit
Is the ECU on the BnS engine to be used in baja reprogrammable? I mean I want to connect a pressure sensor to the ECU...is it possible on the existing ecu or an aftermarket ecu will be required?
strider is offline   Reply With Quote
Old 07-12-2012, 06:23 PM   #2 (permalink)
Super Moderator
minibajaman's Avatar
Default Re: engine control unit
What are you talking about, the Briggs engines are carbureted and there is no ECU. Also you can't modify the engine anyway so I don't know where you would add a pressure sensor or what it would do for you.
Tags
bns engine, ecu, pressure sensor
Adding a oil cooler to Arctic Cat 660 turbo engine stress Motor - Engine 15 10-06-2011 01:26 AM
single unit sled engine Stomper Driveline 77 07-20-2011 08:04 PM
Why is Oil So Critical to My Engine? installers Cooling 1 03-06-2011 04:04 PM
Racing Cost & Information for each Class. TutTech MiniBuggy.net Lounge! 5 08-22-2010 03:22 PM
DIY engine control system build rowycoracing Controls and electrical 64 12-13-2006 02:36 AM
