Results 1 to 4 of 4
    Rorty Striker - not a MiniBuggy but...
    Vendor - Rorty Crisco's Avatar
    Aug 2013
    Sunshine Coast, Australia
    Wasn't sure where to post this but since it's built by Rorty thought here was as good as any place.
    This is a project that has been on the go for a number of years and I'm making a final push to get it finished before the end of the year - depends when the buggy stuff arrives. It's designed to be road registered but primary function is a hill climb and track day car.
    Basic Specs:
    Chassis - RAW Engineering Striker
    Engine - ZX12R, dry sump, Muzzy trumpets, Opcon Autorotor 2076 supercharger, Laminova charge cooler, hacked factory ECU, electric water pump
    Drive train - drive shaft through guilbo flex disc to subbie R160 diff with Quaife ATB centre
    Brakes - Wilwood 4 pot front with scalloped vented ultralite rotors, drilled solid rear rotors and Nissan calipers (with handbrake).
    Tyres - 195/50R15 (old tyres on it at the moment)
    There were some compromises for road registration but all up its going as planned. To comply with emissions regulations (its classed as a new car) I will need to convert it to run on liquid injection LPG (propane). It has a number of advantage including high octane (RON 112) which allows higher compression / boost combo with the supercharger and also some charge cooling (vaporises at -42 deg C). Liquid injection should allow me to use the factory ECU for injector timing - I am yet to sort this part out fully and most LPG parts manufacturers are not interested in this type of project. I have found a manufacturer of small aluminium LPG tanks though which was a major hurdle. If you have experience or contacts let me know!
    In theory it should make about 220kW and 220Nm (300hp) on about .7bar (10psi) boost. Target weight is 450kg (1000lbs) for a power to weight of about 670bhp/tonne.
    At least some of it is comparable to bike powered buggies!
    https://goo.gl/photos/AzzwNyKsJpow9DG67
    https://goo.gl/photos/cRbjxEWQtkjcAgqG9
    https://goo.gl/photos/9WKCrYPT9dXYF8826
    https://goo.gl/photos/XxFVtj1649wr27Cj6
    https://goo.gl/photos/7aMTVjVsnV4ESXbs7
    https://goo.gl/photos/ggidmAUAQe3jAjoYA
    Still working out picture uploads - if they don't work try here https://www.pinterest.com/RortyBuggies/striker/
    The green and orange ones aren't mine but what the finished product looks like.
    Re: Rorty Striker - not a MiniBuggy but...
    I tried to post those links as photos, but it's not working.
    There are some funky things with posting pix that happen here on MBN and I admit that I'm not savvy enough to figure out the software.
    Wild looking machine, by the way.
    Aug 2013
    Thanks K-fab. Probably something to do with Google. I posted an article on rorty.net with pics and used those links
    Aug 2013
    Progress on the ZX12 Striker...
    After a number of mods to the chassis for engine mounts, seat mounts, roll bar mounts, pedal changes and a few others, the welds got cleaned up and I wrapped it up for some touch up paint.
    An hour or three later and Christmas came early with the unwrapping. Touch metal, it should just be a matter of assembly from here on.
    Electric reverse is built and ready for install on top of the diff and cable holes are in for a paddle shift with ignition cut. Dry sump oil tank and radiator mounts are there as well as the mounts for the water to air intercooler.
    I'm going to get it running on petrol before taking on the swap to liquid injection Propane (LPG) for road registration.
    http://rorty.net/sites/default/files...2680_large.jpg
    http://rorty.net/sites/default/files...2676_large.jpg
    http://rorty.net/sites/default/files...2675_large.jpg
    http://rorty.net/sites/default/files...2677_large.jpg
    http://rorty.net/sites/default/files...2679_large.jpg
    http://rorty.net/sites/default/files...2678_large.jpg
  1. Rorty news
    By Rorty in forum Rorty Buggy Group
    Last Post: 10-09-2016, 11:40 PM
  2. Rorty R16 Shotgun II vs. Badland Buggy St4
    By NEbuggy in forum Projects in Progress
    Last Post: 10-08-2014, 09:22 PM
  3. Rorty Buggy Photos and Videos Wanted
    By Crisco in forum Rorty Buggy Group
    Last Post: 11-16-2013, 11:27 PM
  4. Rorty R82s (Bikelomens build) and R16 roller frame
    By Montanaminirail in forum For Sale
    Last Post: 11-11-2013, 02:07 PM
  5. My first buid: Rorty shotgun
    Last Post: 03-27-2008, 10:46 AM
