Results 1 to 2 of 2
    Cold start problem
    Anyone here have any experience with the Weber mpe 750?
    I have a cold start issue. I have spun the teeth off the starter fly wheel gear two times now. Each time the temp was below 30*. It started fine all spring thru summer. This is in a 2007 Revolt.
    Re: Cold start problem
    Dec 2007
    PERTH WESTERN AUSTRALIA
    Have you checked the throwout gear and spring for binding?
    You should be able to manually turn the small starter gear into the spring,then let go and it should all retract.Might just need cleaning,then a LOW temp grease applied.
    Trying to wear out BEFORE I rust out!..........Now just trying to getouta Bed!
    I drink...........therefore I am!
  1. Weber MPE 750 cold start issues
    By Stoneman in forum Motor - Engine
    Last Post: 12-20-2010, 07:46 AM
  2. vw engine problem!
    By peephole in forum Motor - Engine
    Last Post: 11-29-2010, 12:42 AM
  3. Busa motor hard to start
    By bigrock in forum Motor - Engine
    Last Post: 08-02-2010, 12:09 AM
  4. new parts still no start
    By cupcake in forum Honda's Pilot & Odyssey
    Last Post: 08-19-2009, 04:45 PM
  5. Help fuel problem
    By buggito in forum Motor - Engine
    Last Post: 01-14-2007, 09:29 AM
