Results 1 to 4 of 4
    Post subject: 930 cv joint HELP!!!!!
    Okay I bought a Protodie live axel spool for my engine swap. the thing I'm trying to figure out is.... Is there a 23 spline cv joint that will match up bolt pattern wise to a 930 cv joint???? I would like to keep my current axels and hub and save some money well a lot of $$$. I've been looking and looking but with no luck.... NEED GUIDENCE!!! Thanks much all...
    Re: Post subject: 930 cv joint HELP!!!!!
    Senior Member studio5o's Avatar
    Aug 2009
    Nor Cal
    Good to see you made it to the site ....welcome aboard.... to your question I had the same dilemma and unfortunately did not find anything as well ....I know that’s not what you want to hear but maybe someone here has more insight? Good luck with the build .
    I used a front wheel drive rezeppa joint, and machined a step into it, made a flange, and welded it to the step. It was beyond tough, but took a little fabrication.
    I think jgs turbo does the same or similar with the ford joints?
    Bend-Tech Dragon Master
    Nov 2009
    Quote Originally Posted by plkracer View Post
    Yes. Don't be afraid to weld to CV outers, the large diameter makes it strong. 23-spline?
  1. On the subject of race seats...does anyone make a bench?
    By makenzie71 in forum How To Do It
    Last Post: 02-22-2016, 06:04 AM
  2. how to post
    By atvsandcars in forum How To Do It
    Last Post: 06-01-2013, 06:39 AM
  3. First post
    By sandjunkie81 in forum The Welcome Mat
    Last Post: 02-19-2012, 06:29 PM
  4. Subject: Stainless Steel
    By TEO in forum Shop Talk
    Last Post: 11-30-2009, 10:25 AM
  5. post
    By rowycoracing in forum MiniBuggy.net Lounge!
    Last Post: 06-04-2006, 11:29 PM
