Old 02-24-2009, 12:59 AM   #21 (permalink)
Default Re: My ST3 Winter Project
A few pics of the progress so far.
Diesel62 is offline   Reply With Quote
Old 02-24-2009, 02:10 AM   #22 (permalink)
FactoryPhil's Avatar
looking good
FactoryPhil is offline   Reply With Quote
Old 02-24-2009, 03:32 AM   #23 (permalink)
Wheels's Avatar
nice...
08 Rhino
08 R1
Wheels is offline   Reply With Quote
Old 02-24-2009, 04:25 AM   #24 (permalink)
hey man, your build looks good, i've always liked the badlands look (i'm building a modified ST2). the only thing that worries me is your rear suspension design. it looks like the same as the ST2. i never ended up building that design because everything i read said that they don`t hold up. i give it even less of a chance with the weight of two riders on it. are you adding extra bracing to it.
tydra is offline   Reply With Quote
Old 02-25-2009, 01:11 AM   #25 (permalink)
Thanks for the kind comments. Yes i will be adding more bracing to the rear, I got this far and have read everywhere as well about how weak the rear is if built to plans. So im currently looking for a honda manual transaxle to drive the rear. Then i will build around it.
Old 03-01-2009, 03:35 AM   #26 (permalink)
A little more progress this weekend. Front wheels and spindles mounted, tie rods and steering rack mounted. I managed to find a 88 Honda Accord manual transaxle with clutch disk and both axles. so thats also getting mocked up for my rear drive. Thanks goes to (Arrowhead) another builder on this site for his kewl idea. I will be building my rear arms to suit the shorter axle from the Accord for ease of Parts availabilty as well as using the front bearings and axle hub for my rears, for the same reason. why reinvent the wheel when you can just get them from the parts store.
Old 03-01-2009, 06:00 PM   #27 (permalink)
TWR11's Avatar
Send a message via MSN to TWR11
Wow it looks really good, this site is great for ideas, the technology has come a long way in the last five years since i built my buggy. looks like i might have to do some up grades.
TWR11 is offline   Reply With Quote
Old 03-01-2009, 07:53 PM   #28 (permalink)
TWR11's Avatar
I just got done reading all of Arrowheads posts, and now i would like to try the honda tranny as well. im glad that u didnt use the badland buggy gear box design it is very weak and for the last five years since i have built the buggy i have been replacing the shaft and bearings every winter, infact im in the middle of doing that right now. if i didnt have a ton of work to do on my bikes or seals to replace on my quad i would like to atempt this honda tranny this winter, but ill leave it for next winter. i was wondering where in alberta u live because if u lived close enuf maybe we could put our heads together on this.
Old 03-01-2009, 11:20 PM   #29 (permalink)
Hello westerners from an easterner
Having just finished my badlands sabertooth buggy, it seems funny to me that if this drive line from badlands is so pron to problems why has Bruce not redesigned it there are a far amount of these buggies being built ? No one seems to be happy with the design I know I wasn't less than 100 miles on it keyways stripped and keys bent out of shape (this with only 500 cc quad motor and CVT).
Keeps us other builders posted on Arrowheads design installeed into the badlands frame I've read his posts as well sounds like a good design
Good luck the build Sodman
sodman is offline   Reply With Quote
Old 03-02-2009, 01:12 AM   #30 (permalink)
Admin
Gene's Avatar
Good question Sodman. Continuous improvement is a virtue.
Gene is online now   Reply With Quote
winter project 455bird Projects in Progress 3 12-04-2008 07:50 PM
Bugs winter project.... Bugpac MiniBuggy.net Lounge! 32 10-15-2007 04:14 AM
Project Logs amergin MiniBuggy.net Lounge! 0 05-21-2005 12:41 PM
