Old 01-06-2009, 10:57 PM   #11 (permalink)
Default Re: My ST3 Winter Project
The polaris RZR is 50 inches wide and thats the max. Neighbor has one and there's not much to the a-arms.How is the saeting? Like is there enough room side by side with another person sitting next to you?
Old 01-07-2009, 01:46 AM   #12 (permalink)
There is plenty of room side by side. Or seems to be, I've just started bending tube and tacking it together. Not sure how you will pull off the 50 inch width. You'd have to sacrifice alot of travel to pull it off.
Island Buggy is offline   Reply With Quote
Old 01-07-2009, 03:36 AM   #13 (permalink)
Have any pics of your progress?
Old 01-26-2009, 03:18 AM   #14 (permalink)
How much tubing is needed to build the ST3? Just the chassis not including the a-arms.
Old 01-27-2009, 02:14 AM   #15 (permalink)
Make your cut as what the plans state. If you have your plate work cut already(which you should before going any further). I highly recommend that you have all your plate work cutout before you even think about building the frame. you will find that the plate work also help Greatly when tryin to figure out placement/FItment of your frame.
I bought 200 ft of tubing, and I have about 20 ft left. Most of that will go when i build the rear control arms.
DO you have the cad file for the plates? if not pm me. I had to ask for that separately From badlands, it wasnt included with the online plans.
Feel free to Start your own build thread and let us know how it turns out.
Diesel62 is offline   Reply With Quote
Old 01-27-2009, 02:19 AM   #16 (permalink)
Not a problem. Thanks for the info.
Old 01-27-2009, 03:06 AM   #17 (permalink)
Spec for those who were asking.
ST3 Two Seater Specifications:
Wheelbase = 90" Wheel Track = 66"
Wheel Travel = up to 14"
Overall Length = 120"
Suspension = Independent Double A-arm (front & rear)
Steering = Rack & Pinion
Seating = 2 Bucket Seats
Braking = Hydraulic Disc Brakes
Weight = 700-800 lbs
Engine (recommended) = 600cc or larger Motorcycle engine
Old 02-19-2009, 01:42 AM   #18 (permalink)
Gentlemen, My brother and I are both building ST3s. They are coming along rather well. I have seen a lot of postings about the bushings. I got my from Kartek Off Road - Where Off-Road is On!. They have exactly the size that is needed for the build. Incidently I see that a lot of people are using the Subie rearend with shaft drive engines. We are both using shaft drive engines. For the differentials we are using Eagle Talon LSDs (got mine on Ebay). They fit really well.
PrairieSlider is offline   Reply With Quote
Old 02-19-2009, 01:59 AM   #19 (permalink)
PrairieS, what size of tube did you use for your bushings?
Old 02-20-2009, 03:49 AM   #20 (permalink)
They are Kartek P/N AFB-125 bushings (Urethane) with a 0.5" id and 1.070" od for 1" black pipe. Pretty standard. The phone number for Kartek is 951-737-2999
winter project 455bird Projects in Progress 3 12-04-2008 07:50 PM
Bugs winter project.... Bugpac MiniBuggy.net Lounge! 32 10-15-2007 04:14 AM
Project Logs amergin MiniBuggy.net Lounge! 0 05-21-2005 12:41 PM
