#12 (permalink) | |
PM Rorty or contact him and ask him as he is a member on the site and it's his plans you can tell you exactly what you should do or how to go about doing it. And you guys are right I just need glasses you do have a degrees on it. Good, good. ![]() ![]() |
#13 (permalink) |
have some pics of the tranny all cut up... I just need to run it through the glass bead blaster to clean it up, replace the main shaft bearings, and put it back together.
![]() I bend my first set of tubes today!! I wish they were for my buggy. they are for the rock sliders I'm building for a client's truck. I have a few more supports to make for the sliders. that means I get to use my new drill press and tube notcher. i figured i would get another press so I can just keep it in there all the time. is there a way to keep the bends flat? I put a level on the end and made sure it was level before I started bending. just didn't know if there was a cool old school trick someone would share. or if I'm on the right track...
Clay Watson Kustom Kar Audio Boulder,CO alt.6000' |
#14 (permalink) |
site down the tube and then site the old bend going through the die.
That's about the only trick I know. Don't site off the top of the die but where the tube runs into the die and then down the bar when they blend together that's about it. After time your bender gets off balance or long tubes will be hard to use a level on so siteing them may be your only way. That's what I do. If a bend is off a little you can usually slide a piece of tube over the bend and lock the other side into something and then twist the tube to correct them. This can also save you if it's just a small amount of twist. Those bends look good and cool you get to use the bender even if it's not for the buggy yet. ![]() |
#15 (permalink) | |
You need a POB to attach to the end of the tube so that you keep the tube from twisting. Better yet when you need to twist the tube 23.5 deg you can do it. I made my own but you can get one from Captainfab and attach your own digital level. OFN Forums Louis |
#16 (permalink) | |
#19 (permalink) |
Any fab guy can attest to how frigg’n long it takes to make something for the first time. The diver’s side took forever and passenger side took seconds.It turned out good.
I hope to be on the buggy later this week!
#20 (permalink) |
this sounds like a sweet project
about your sub frame idea i wanted to let you know that my buggy has one its kinda nice the motor is hard mounted to it and then the sub frame it rubber mounted to the chassis
06 Joyner 250cc sand spider metalic red 17 gram sliders blue main spring black mrp cdi extra lights rzr shocks on the rear |
| Louis' R82s Build | louis | Projects in Progress | 71 | 11-04-2009 12:37 AM |
| My R82s Build | malder | Projects in Progress | 14 | 03-15-2008 04:22 PM |
| The Next Rorty R82s build | dune | Projects in Progress | 416 | 11-17-2007 04:30 PM |
| Twin Seater buggy plans (rorty R82s) | gordy | Frame | 6 | 05-13-2006 05:08 AM |
| Blogs vs. Projects in Progress | Kludge | MiniBuggy.net Lounge! | 3 | 04-11-2006 05:01 AM |
