#21 (permalink) |
944 use Type IV CV's. 100mm od and then the rest - uh, check the link again...
![]() 930 cvs are 108mm od. I have a set of 944 axles - I'll try to get you some measurements - oal of the axles, distance between the CV bodies in the next couple days. If I don't post something by Sat, badger me about it.
#25 (permalink) |
Better change that post before Yoshi sees it or you'll have a war on your hands lol. Personally, I think you'd want to go heavier duty on the a-arms. Arrowhead managed to pull off .065 somehow, but to be safe, I would go with the thicker stuff.
#26 (permalink) |
Never heard of a 7. something to 1? It's made for a Dana. The input shaft has 7 teeth, and the teeth are cut into the shaft. It's not much larger than the input shaft itself. Granted it is heavy, but it is out there. I should look into running a tranny like arrowhead, but gut it, and use 1 gear.
| new, need help and ideas | seanblv | Projects in Progress | 17 | 04-27-2007 03:51 AM |
| diff ideas | Bugpac | Driveline | 64 | 01-13-2007 10:09 PM |
| Ideas | action | Suspension - Wheels & Tires | 5 | 03-01-2006 11:25 PM |
