Old 08-07-2008, 06:27 PM   #21 (permalink)
Administrator
K-fab's Avatar
Default Re: need some ideas !!!!!
944 use Type IV CV's. 100mm od and then the rest - uh, check the link again...
930 cvs are 108mm od.
I have a set of 944 axles - I'll try to get you some measurements - oal of the axles, distance between the CV bodies in the next couple days. If I don't post something by Sat, badger me about it.
Old 08-07-2008, 08:04 PM   #22 (permalink)
Send a message via Yahoo to vidio1
The link you posted, axles_cvs , has lengths for the 944 axles. Apparently Porsche 924/944/VW 181 Thing are all the same. They are all grouped together anyway.
vidio1 is offline   Reply With Quote
Old 08-07-2008, 08:59 PM   #23 (permalink)
Xcalibur's Avatar
yeah i seen they grouped those together also ?? are they interchangeable then for stub flanges ???
Xcalibur is offline   Reply With Quote
Old 08-07-2008, 09:01 PM   #24 (permalink)
Xcalibur's Avatar
also im ordering some tubing, 1.25 X .095 for frame then would like to go 1 x .065 for a-arms and trailing arms ??? is that too thin or should i 1.25 x.095 the whole thing ?????
Old 08-08-2008, 03:06 AM   #25 (permalink)
Better change that post before Yoshi sees it or you'll have a war on your hands lol. Personally, I think you'd want to go heavier duty on the a-arms. Arrowhead managed to pull off .065 somehow, but to be safe, I would go with the thicker stuff.
anasasisxenophontis is offline   Reply With Quote
Old 08-08-2008, 05:49 AM   #26 (permalink)
plkracer's Avatar
Never heard of a 7. something to 1? It's made for a Dana. The input shaft has 7 teeth, and the teeth are cut into the shaft. It's not much larger than the input shaft itself. Granted it is heavy, but it is out there. I should look into running a tranny like arrowhead, but gut it, and use 1 gear.
Old 08-08-2008, 08:41 PM   #27 (permalink)
Xcalibur's Avatar
Check these out, just stumbled across them a few days ago, very nice rigs, and reasonably priced !!! sandfever.com
Old 08-09-2008, 05:37 AM   #28 (permalink)
Admin
Gene's Avatar
I like the overall look. Most important is that the car seems to have good suspension geometry. Same car as the pink girly car with butterfly wings.
Old 08-19-2008, 12:51 AM   #29 (permalink)
LockedupXJ's Avatar
sorry wrong post
LockedupXJ is offline   Reply With Quote
new, need help and ideas seanblv Projects in Progress 17 04-27-2007 04:51 AM
diff ideas Bugpac Driveline 64 01-13-2007 11:09 PM
Ideas action Suspension - Wheels & Tires 5 03-02-2006 12:25 AM
