Old 07-19-2008, 08:01 AM   #51 (permalink)
flyerrider's Avatar
Default Re: Aluminum side panel teaser photos
No offense but that looks like a good way to waste a set of lights. First roll and they are history. Does that price include the hoop?
flyerrider is offline   Reply With Quote
Old 07-19-2008, 06:35 PM   #52 (permalink)
Its more incentive to keep the shiny side up. Desert racers run roof mounted light bars all the time. They typically have 6 HID's across
the roof & those lights are about $500 EACH + a good light bar from
a reputable shop is around $1,000 depending on design. Their's are
almost always QD or bolt in [like mine]. They put them on just before
dark so they don't have the weight or run the risk of smashing some
lights until you really need them. Where would you propose we mount
lights?
jp350 is offline   Reply With Quote
Old 07-19-2008, 07:16 PM   #53 (permalink)
Send a message via AIM to Creativeness
Lights could be placed on the sides if you have nerf bars, but if you dont its the same result. Too big for front bar too..
Smaller lights are the only real save here, and you can probably find a set that puts out enough light for a racers need.
Creativeness is offline   Reply With Quote
Old 08-08-2008, 04:55 AM   #54 (permalink)
Got side panels?
Old 08-08-2008, 11:48 AM   #55 (permalink)
Administrator
K-fab's Avatar
JP - the work you do looks great!
A little powder coating and they'll be killer.
Old 08-10-2008, 03:25 AM   #56 (permalink)
Thanks K-fab. Powder coating would look nice or better yet custom graphics. I sell all my products raw so that the customer can coat to their preferance. However if a customer wanted me to arrange for powder coat I can do that. I also know a girl that does really nice custom paint.
I was out in the desert all day today laying out the course for the MDR night race next weekend. I should have some time tomarrow to get more aluminum work done. I will post more pics in a couple days or so.
Old 08-12-2008, 03:11 AM   #57 (permalink)
Here are a couple pics of side panels with a stepped pattern in them rather than a bead & no air scoop cut out [for water cooled odysseys]
Old 08-14-2008, 02:40 AM   #58 (permalink)
Here are pics of a full set of panels, a partial set on the car to show the air scoop cut out, the clamps & hardware that come standard, & samples of the optional Dzus hardware
Old 08-15-2008, 06:08 PM   #59 (permalink)
jumpin jellybean's Avatar
sweet looks good and well thought out
Old 08-27-2008, 04:54 AM   #60 (permalink)
Thanks Jellybean. For those of you not familar with Dzus hardware I thought I would provide you with the names of the components & an explanation of how they work. In the upper left of the last pic in my previous post there is a lightweight tab. To the right of that is a standard 3" long tab. These are welded to the chassis to accept the button & spring. Directly below the lightweight tab is a spring. It is riveted to the tab after the tab is welded to the chassis & the chassis is recoated. At the bottom left you have a counter sunk [flushhead] Dzus button. These are also avaiable in a button head [domed]. After locating & marking the panel you punch a hole for the button to go through & in the case of the counter sunk button you dimple the panel with a special tool so that the button sits down in the dimple & flush with the top of the panel. The cam way cut in the button indexes on the spring & with just a quarter turn the button is firmly locked in place via the cam way & spring tension. At the bottom right there is a spring loaded captive button. These work the same as the standard Dzus button but are of a self ejecting type & are retained in their mount which is riveted to the panel.
