#11 (permalink) |
Here are a couple pics of the main side panel w/ the 1/4" bead in it. I will be revising the panel somewhat but this gives you a pretty good idea what the finished product will look like. The other pic is of a roof mounted number plate I made. I used some numbers I had laying around so they are a bit fat for the panel. I have a few other designs for number plates I'm playing around with. These are 8" numbers. Does anyone run smaller ones [eg: 6"] ?
Edit: I have added a pic showing a cross sectional view of the step, 1/4" bead & radius roll respectively. Last edited by jp350; 08-06-2008 at 08:42 PM. |
#12 (permalink) |
As of right this moment this thread has 368 views but not many replies. I welcome comments, both good & bad. But please limit any "bad" replies to constructive criticism. I'm always curious to know what others think of my creations. Thanks & have a good one. * *James
Custom fabrication available. PM for details. |
#15 (permalink) |
No sir. A tight radius like that can easily be produced with a special die on my bead roller. I have a very expensive bead roller but when you consider how versatile they are, the cost is more then justified. * James
#16 (permalink) |
Cool. Seems like it will roll it without waves.Can you post up an end view pic showing how straight an edge it will accomplish with that roll?
#17 (permalink) |
Thanks for the compliment. Yeah panels are about as easy as it gets. I would like to do something way more trick then simple panels like these but its difficult to justify. When you start shrinking, stretching, etc it takes a lot more time. * * *James
#18 (permalink) |
Dang, if this is simple for you.... I'm amazed! I've worked with some thin aluminum and it's not easy. Just messing with a brake and press is hard enough for me.
Edge Barracuda powered by a 2002 GSXR 750 engine with Fox air shocks and other goodies. It finally moves!
#19 (permalink) | |
. There really is minimal stretching/shrinking in a radius like the one in question. With other shapes thats not the case & the part has to be straightened.James
#20 (permalink) |
I've been fortunate to work with some very talented & well known fabricators in desert racing & I've learned a bit from them. What they produce is a true thing of beauty. It almost makes you jealous. But that just motivates you all that much more to continually improve your own skills.
