Old 03-28-2008, 08:19 AM   #21 (permalink)
Super Moderator
TutTech's Avatar
Default Re: Low Cost Race Car? Now with Pictures
Nah thats the easy part.
I hardly had to weld anything just any bars that were about to be covered by
another bar.
Everything else is just tacked and almost no bent bars yet at all.
So this was very fast.
I then used my notes and just shrunk things down a bit.
Well about 6 inches and 3 inches.
Thats not too bad.
And so I have a good idea of size and looks now.
I will get one of my brothers seats and set it up just for mock up so you can get an idea
of the size of it also first chance I get.
I will be off this weekend to go racing with my brother at the Mint 400, if any of you are
going stop by and say hi.
Thanks for looking.
Tut Tech Racing
Old 03-28-2008, 11:55 AM   #22 (permalink)
Administrator
K-fab's Avatar
Good luck at the Mint. *Keep the rims round and the tires full of air! *[smilie=blowkiss.gif]
Old 03-28-2008, 08:10 PM   #23 (permalink)
Good luck this weekend and your project looks great!
suicidaltendencies is offline   Reply With Quote
Old 03-28-2008, 08:45 PM   #24 (permalink)
Super Moderator
TutTech's Avatar
Thanks guys. We will do our best.
I have to run out the door to try to beat Vegas traffic so see you all Monday.
Tut Tech Racing
Old 04-09-2008, 12:48 AM   #25 (permalink)
Super Moderator
TutTech's Avatar
Ok had a couple hours to do a little more this week.
So here is what I have been up too.
As a bone stock buggy class the actual VW size and parts usually need to be used.
So I cut the rear torsion out of a vw pan and installed it into the car
Here
The newly designed front end with raised hood section.
I wanted the front to actually have a hood and nice slope up and this will also make for an
actual dash. New and I think it will be cool but I will only know after the aluminum is
on and how good he makes it look then I will know.
and a side shot of it so you can make out how its raised up.
Ok thanks for looking and my low budget race car continues.
Tut Tech Racing
Old 04-10-2008, 02:52 AM   #26 (permalink)
Default Re: Low Budget Race Car? Now with Pictures
Tut- *I've got a question. *Is this going to be a Class 9 car? The reason I ask is the front end you show in the pics is a king pin. I thought that only Ball joint front ends were allowed in Class 9. You race in MORE, perhaps MORE is different. I've been looking forward to see what you do within the confines of the stock VW suspension dimensions. Looking good as always! Can't wait to see the finished product!
CABRIOLET is offline   Reply With Quote
Old 04-10-2008, 07:11 AM   #27 (permalink)
Super Moderator
TutTech's Avatar
No, no I am not using the link pin.
Good eye by the way.
I have several link pin front ends because thats what I use.
So I do not have a ball joint front end right now but using the link pin I can
atleast get an idea of width, tire rubbing, front to rear wheel base etc.
Ya I am waiting for my brother to bring up a good ball joint front in.
Good call and your dead on.
96 inch wheel base.
Total length of car tip to tip will be under 12 feet.
Width to outside of tires looks to be 56 inches wide to outside of tires so far.
I picked up more parts today so I will mock up seats etc. to get a feel for the cab area
and what not.
I met with my brother and off of photos he picked a rear cage he like so I will set that up.
And the front I can do some but dont want to go to far until I have the ball joint front end.
Anyways thanks again for the kind words and some feedback,
Thank you.
Tut Tech Racing
Old 04-10-2008, 07:06 PM   #28 (permalink)
Was just wondering about the king pin front end. It would be great if the rules were changed to allow it. Are you going to put in a torsion adjuster in the rear?
Old 04-10-2008, 08:55 PM   #29 (permalink)
Super Moderator
TutTech's Avatar
No my brother ended up going against it just because of cost.
Not so mucht he adjuster but if hes going to do all that then he should buy
a chromoly rear houseing with adjuster and end plates.
Several hundred dollars... or just stay stock and atleast get the car out there.
That is a total upgrade and option and I would recommend it normally
but if you new my brother anything to just get the car done and get it out
there is more than he will ever get done himself.
He has started atleast 24 projects and sold them half way through.
So I am trying to speed things a long save cost and keep him going.
I just bought this week the most current additon of the Score Rule book from Score
themselves and no sorry no changes and no link pin.
I even called Jim the owner of MORE and asked if we could run it and he said NO.
This weekend I should have more to show as my brother is going to come up and
help me do some work and come up with ideas etc.
Thanks again for the great questions and I hope I have been able to help and answer them
for you?
Tut Tech Racing
Old 04-10-2008, 11:12 PM   #30 (permalink)
It is really good to see a true low budget build. It will be an inspiration to a lot of folks. *I thought you might put one in the stock housing but at that point, as you said, might as well just put in an aftermarket torsion tube with adjuster. Are you going to keep the rear frame horns? With your chassis design it looks like there is plenty of room in the cab. I like the raised tube for the dash. Great work!
3rd Annual Powder Puff Race. Oct. 11/08 TutTech Events and Group Gatherings 9 10-09-2008 06:04 PM
Mint 400 Race Report & Pics. TutTech MiniBuggy.net Lounge! 8 04-02-2008 04:33 AM
Powder Puff Race for the Cure TutTech Events and Group Gatherings 7 10-22-2007 05:29 PM
Short Race Car? TutTech Projects in Progress 46 06-30-2007 11:40 PM
NOORA Mini-Buggy Race pics and videos Sonic Offroad Andy Show off your toys in here! 0 06-13-2006 03:52 PM
