Old 04-19-2007, 05:53 AM   #1 (permalink)
Super Moderator
TutTech's Avatar
Default Short Race Car?
Well I guess this car would fit under Small Big car?
Or Garage Racer.
Midi Size Buggy?
Or something along those lines.
I have built cars for awhile now nothing special just buying the parts
and putting them together I am by no means an awesome fabricater.
I just like to build things.
Heres a small run down,
after a few years of building buggies for the sand (vw engine and parts)
I built my first race car.
Kinda big in my opinion especially for a 2 seater.
VW powered with VW front beam and rear arms with a 115
inch wheel base and 14.5 foot overall size I raced for awhile in the VW class until it was stolen.
I then switched and built a sand car.. VW A-arm 2 seat 105inch wheelbase
2332 VW Turbo car.
I will post some pics in the oppropriate section later.
Anyways after a year or so the racing bug was eating away at me and I wanted to race again.
So I did a baja.
It was good and fun and lasted about a year.
I let my wife race it and it eventually broke down on her.
I have always wanted to build a smaller car.
I always have and finally I did.
This project is all out of my own garage with pretty much normal tools,
alot of lowbuck tools and a Lincoln none bottle mig welder.
But anyways I dont mind and enjoy building so off I went.
I build what I can and buy what I cant.
So I bought a front beam actually took the one out of my bug.
I bought some rear arms for 930 micro stubs and disc brakes.
Then I set up and designed my own frame.
I was going to go a little shorter but with the arms and size of tires I want
to run in the desert I finally went with the 95 inch wheel base.
So with those parts I got started.
I built a frame with the measurements I worked out from prior builds then
just shrunk down where I wanted the car to be smaller.
I just worked through the car step by step like setting up a seat to see how tall I wanted the sides and roof and went from there.
At first glance it looks a little long without all the rear stuff in but its actually going to be tight with fuel cell, engine, tranny, torsion houseing, battery, oil cooler, shocks and of course a spare tire and even more stuff.
Anyways Then I set up the front beam and tied it into the car.
Same with the back torsion houseing (or pivot tube as I will be running coil overs)
Here take a look
and another showing the back
I just have been keeping at it adding to the car as I get parts etc.
I think so far I am about 6 weeks into it.
Here is another shot of it just showing how much cross braceing I am running nothing like having plenty of saftey when your small and running in the desert.
And I have added even more braceing etc since that shot too.
As I said everything is built in my garage so nothing special when it comes
to fabrication so here is my simple yet affective rear shock tab system
Here is the car with the tires just barely on so I can check my CV, shock, axles and well just about everything clearance.
It all checked out so the tires will come back off so I can work on the car some more.
Tons of welding to do and alot of work still to come.
Anyways I think this is a cool project to do in my own garage and then go
out and race it and see how I do.
I race locally with MORE Racing.
We just run through the local deserts like Barstow when we race no Baja etc.
Trophy only class.
Thats where I am at so far.
Let me give you guys the specs on the car so far as well.
Tut Tech Race Car Specs
The specs on the little buggy:
The buggy is 12 feet long from rear bumper to front bumper
It has a 95 inch wheel base and is a 2 seat buggy
The width of the buggies cage is 45 inches at the bottom section in the seating area and 55 inches wide at top of seating area.
Sides are 25 inches high from floor to your shoulder
The roof is 50 inches tall from bottom of car to top of car.
The buggy can seat people as tall as 6 foot 4inches.
The front end width is 60 inches wide to the brakes
The rear is just over 60 inches wide to the brakes.
The front and back our an addition 10 inches wider with the 5 lug hubs on.
Making the buggy just around 75 inches wide front and 80 inches wide in the rear.
Tires are Dunlop 30inch by 9inch mud terrains.
The rims are Centerline rims 15x5
The buggy is heavily supported with tons of cross bracing and a lot of reinforced corner sections.
Some points of intersections actually have 8 bars tying into one section to make this little buggy very strong! Which means Very Safe!
The buggy is simple and made from 1.5 inch steel tubing and 1 inch steel tubing, both in .120 wall for maximum strength.
Engine & Suspension:
16 gallon safety fuel cell with an approx. 125 mile range
VW Engine single 40mm Weber carb
A 091 Bus Tranny, Both Motor and tranny were built by Sandrails Unlimited.
930 CV's with 300m axels.
Axels are 28 inches wide
934 Micro stubs with 930 stub axles and 4 piston disc brakes
20 inches of Rear wheel travel (buggy is strapped at 18inches so I don’t brake a CV)
And 15 inches of front wheel travel.
2 inch Coil Overs front and rear with a triple 3.0 fox bypass's in the rear to control this little buggies ride.
Some Input on how and why I think this buggy will work:
The buggy is very stable.
The 95 inch wheel base makes this car turn easily and very easy to control.
With the buggy being nearly as wide as it is long is why its so stable.
Short and small to get into and out of hard to drive places. Very easy to traverse rough sections of the desert or rocky, washed out, rough, hills well a lot of terrain that’s bad for longer buggies to get hung up and not be able to turn tight and run through this little buggy can is my hopes and plan.
It will just run better in the technical courses and in and out of the stuff the larger buggies have trouble with.
In my local deserts there’s a lot of that so I am hoping this little buggy does
well.
The buggy may look like it has very simple construction with a nice look to it but it is also very well thought out as I have built several buggies and worked out several ideas to lead me up to the building of this little buggy.
The buggy is small without looking small or without you feeling small when inside, in fact you have plenty of room inside this buggy.
The buggy has a nice look to it with out it being long actually the overall length of the buggy is only 12 feet. Very cool.
The buggy could be smaller in other none race versions but do to fuel cell and other race gear this buggies overall size is a little longer.
Racing:
So far my wife and I have raced the little buggy at the MORE 400 mile race.
With 8 buggies in our class and over 130 total cars racing we placed
4th in our class.
We had no fabrication problems, welding problems, design problems and the buggy worked exactly as we had hoped.
I can actually say it exceeded my expectations.
It is nimble, quick, very stable, runs through whoops very quickly even for its
small size, easy to drive and did I mention a lot of fun.
The race was awesome and we cannot have hoped for more with our first showing
And minimal testing on the buggy.
We had a couple flats to fix, a fuel pump left us stuck out on the track for 2 hours and a bad alternator left us stuck for nearly 1 hour.
We had other small problems as well so with all this and we where still able to bring in a 4th Place at our first race is great and I cannot be more happy for the first showing of the car.
I hope to be in the top 3 soon.
That’s all for now,
Thank you.
Tut Tech Racing
Old 04-19-2007, 07:37 AM   #2 (permalink)
Admin
amergin's Avatar
Default Re: Short Race Car?
Wow, nice detailed post. Would be nice to see such detail as you build along. I think there is plenty of room for all types of buggies on this site. Most of the components other then the engine and tranny carry over anyway.
amergin is offline   Reply With Quote
Old 04-19-2007, 07:46 AM   #3 (permalink)
Super Moderator
TutTech's Avatar
Ya I was a little worried about that.
But I know my wheel base and size of the actual car is well a small car.
Especially if I did not have to run a fuel cell I would have pulled this car into
a 85 inch wheel base no problem.
Thanks for the feedback and I thought I should explain my car and why/how
I was building it.
Plus I hang with a group of V-8 junkies so I am the small car.
Especially VW powered.
But my wife and I our big VW collectors and rebuild our classic VW's etc.
So I like the engines etc.
But I just want a smaller car to put my engine in instead of getting a bigger car just to put a bigger engine in.
Anyways I have seen all types of engines on this site so even though I am VW powered the size of my car being so small is what made me post here more *than any other site. Oh and reading your posts and seeing how nice and informative you guys are.
Actually this is the only site other than my own blog/site that I have posted to to let others see it.
I figured as you are all mini buggy builders you would appreciate my work and what I am trying to do more than anyone.
Yes alot of my parts are the same and some are not but I think the car is turning out very well for the parts I used.
I will keep updateing as I move into wiring, engine, body panels, paint, etc.
I hope to actually have this car done for a race in March... very end of March Memorial weekend race.
Set a goal stick to it and if I make it then fine.
If I dont no worries I will make the next but its good to set a goal so
I push myself.
Again thanks for the kind words and feedback.
Tut Tech Racing
Old 04-19-2007, 08:40 AM   #4 (permalink)
Admin
amergin's Avatar
The size fits in just nice here so I wouldn't worry about it one bit. Besides, sounds to be like you have some knowledge from building two rails that would make a great contribution to the site.
Old 04-19-2007, 12:34 PM   #5 (permalink)
renegadespec1's Avatar
Welcome Tuttech,
nice detailed post, good introduction...Build looks great...I think tou'll be a good fit here..
EVIL 6's LOOSE CANNON
renegadespec1 is offline   Reply With Quote
Old 04-19-2007, 05:09 PM   #6 (permalink)
Super Moderator
TutTech's Avatar
Thanks alot guys I was a little worried as I am not Motor cycle powered.
But Ya I have seen a few guys cars that are bigger than mine.
So I figured I could fit my car in even with the different engine.
Well an update the aluminum shop called and can fit my car in.
Ok a little early because the car is not even fully welded or
done but its tough to get your car into these guys the're all so busy.
So I will take it down today and when I get it back I will get some shots
of it with the body on.
Then I plan to send the body to powder coat and get back to work on the car.
All tabs or pieces that will be in the way of the body are done so I am
not to worried and If I missed anything I think I can trim or fit it.
Why the car is at aluminum I can work on making some cash so thats a good thing.
Then when returned I can start to fully weld the car and start to assemble
the rest of it why the body is at paint.
Like Engine, all of its coils, coolers, filters, etc, then spare and jack mounting
stuff like that.
So I think this will actually work out alright.
And I think I will still be all set for the End of March race which is being
Held by one of my sponcers so I really want to make it.
Anyways thanks again for allowing me to post and be a part of the site I really appreciate that because after reading and seeing this site I really wanted to be a part of it as I believe we all like our smaller cars.
Thanks.
Tut Tech Racing
Old 04-19-2007, 05:39 PM   #7 (permalink)
Admin
Gene's Avatar
Welcome to the site Tut!
Nice work and looks like a good fit for you and this site.
Keep up with the posts and I know that members will benefit from your knowledge and experience.
Old 04-19-2007, 05:52 PM   #8 (permalink)
BANNED
A mini is a mini.You're cool with me!
Old 04-20-2007, 08:25 PM   #9 (permalink)
Super Moderator
TutTech's Avatar
Thanks alot guys for the warm welcomes and allowing me to join it.
Thanks.
Well nothing much to update but the car did make it to the sheet metal shop and they are getting started.
So wount have an update for the next week or so.
But as soon as the panels are on I will snap a shot or two.
The aluminum guy and I had some ideas on how to make the car look
longer not as short etc with panels and what not.
Sounded good will see how it turns out.
Nothing fancy as 1 this is for racing and for learning and 2 I did not have
thousands of dollars to have custom hoods and pods made for the side etc.
So a nice basic job. But hey it will look totally different with a full body I am shure.
Well thanks again talk to you soon.
Tut Tech Racing
Old 04-20-2007, 09:43 PM   #10 (permalink)
Ive been known to ponder with vw stuff, Thats were the name originated years ago...
sorry for hijacking with pics, let me know and i can remove them...
