Old 08-23-2006, 07:20 PM   #21 (permalink)
Default SCORE
Hey, Moskito! How's it going? Throttle here............oopps wrong board!
Nah, been hanging out here quite a bit lately - trying to learn about building my own car, since I sold all but one Pilot. Anyways, do you still know the requirements for Stadium racing (or SCORE) - size, weight, engine, etc. I would like to try to get some interest around SC and run on motocross tracks. Whattcha think? Will I see you at the H-M ride comming up? Hope so.
throttle is offline   Reply With Quote
Old 12-25-2006, 11:41 PM   #22 (permalink)
Administrator
K-fab's Avatar
Default Re: K-fab Short Course CORR Super Buggy
The short course car got put on hold back in August - CORR left, WSORR came in, I'm worried about having a sanctioning body, so on and so forth. *
I also have a 10 car in the process out in Phoenix that's about 70% done. *
What in the world am I thinking??? *
Well, I think I'm back on track... (not the track, per-say) *
And, I'm gearing up to possibly get into the buggy market... *
Right now I'm still in the planning stages - so things will more than likely change a lot - but here's the basic plan:
The Goal: *Start manufacturing Off Road Vehicles
I'm going to build three cars (probably in this order): *
Short Course Car *
Sand Car *
Desert Race Car *
All three cars will share the same chassis - each with tweaks for the designed use. *I've been designing this thing for a very long time, and I have a couple people with huge amounts of knowledge helping me out a bit. *
All three will have the following equipment (a bit redundant - as I listed most of this on the first page of this thread) *
Howe steering rack (power assist on the short course and maybe the desert car)
More than likely Wilwood rotors and calipers. *
930 CVs *
Fuel Safe fuel cell *
Team Tech harnesses *
K-fab hubs *
K-fab spindles. *Hollow 1.75" front axles on billet uprights
Quick release steering wheel *
Braking bias LEVER, not knob *
CNC or Wilwood pedals and master cylinders *
C&R Radiator *
Powered by??? *Honda VTEC or maybe a Toyota for the two race cars. *Sand Car? *Not sure yet *
All will be a CVT setup w/o a diff. *I have a couple options - RPM and something else, maybe... (I'll know more soon enough) *
Still not sure about wheels - ATX Series for the desert car - provided they come out with the Wide 5 pattern. *I was told by a rep, while in Baja, that they were working on 15 x 6's. *
Probably Centerline 15 x 5 up front, 15 x 7 in the back on the Short Course car and Douglas (maybe 12"?) for the sand car. *
Sand & Short Course Car - 300M axles, Desert Car - still in planning. *
Sand & Short Course Car - Fox or King Coil Overs, Desert Car - still in planning. *
Sand Car - Beard or Mastercraft seat, Short Course Car & Desert Car - Sparco seat. *
Brake setup: *
Sand Car - two piston calipers up front, solid rotors. *Single rear four piston caliper in back, solid inboard rotor *
Short Course Car - four piston calipers all the way around on vented rotors, rear are inboard *
Desert Car - four piston calipers all the way around on solid rotors, rear are inboard *
I'm shooting for travel in the 20" - 22" range on all four corners of all three cars. *
Up front they will all have dual A-arms. * *
Out back the Sand Car and Short Course Car will have dual A-arms. *I'll probably use non-plunging CV's as I will have almost no axle plunge. *
Desert Car will have trailing arms and standard CV's. *
Wheel base will be around 95 inches - maybe a tad longer (Desert car - 100") *
width - 80" - 84" range, depending on wheels *
I'd love to have the sand car come in at 1,000 lbs. Probably closer to 1200, though
Short Course car sucks - rules state 1580 w/driver. *Pig City!
Desert Car - 1500 or so. *Building it to SCORE specs.
More info: *
My front spindles will have bolt in axles. (pix on first page of this thread) I'm planning on making the uprights out of 7075. *I love the CNC machine! *- and this project is forcing me to move to the next level of 3-D machining... *I need to go back and take a couple refresher classes on my CAD/CAM software. *(Bobcad) *
I already have a 1.75" od hollow axle designed for the desert car - uses tapered roller bearings in a fairly narrow hub - very stout.
Rear hubs - I have to find 108mm i.d. tapered roller bearings - but I need the OD to be as absolutely small as possible. *I could probably get away with a dual row angular contact bearing setup on each end of the hub - but tapered rollers really are the way to go on something like an axle... *
The outer hubs will be mid-board CV's. *No stub axles. *I did a similar setup on the Moskito's original rear hubs. *Since I was using Type IV CV's I was able to source a 100mm i.d. bearing fairly easily. *Makes a nice tidy unit that's narrow, light and has few pieces to go bad. *The new ones will not be five link setup, though. *Two suspension mounting points - upper and lower heims, along with a third link that sets/controls toe. *See pix on first page of this thread for an idea of what I'm talking about.
On the desert car - shocks & axles: *I want to see how the new stuff works on the car out in Phoenix first. *If the items end up working well, I'll incorporate them. *If not? *- tried and true Fox or King and regular plunging u-joints and axles.
I spent most of the past couple months chasing tools, machine stuff and building a chop saw station, build/jig table and getting set up. *I still need to put the coping grinder on a stand with wheels and I still need to build one more mobile work station to hold an abrasive cut off saw, grinder, belt and disc sander, 3-in-1 shear/brake/bender.
I've spent the past week doing CAD work and designing/drawing the car. *I almost have the front spindles done on the computer.
Unfortunately, I'll not get to do squat for the rest of the week. *Gotta go on vacation with the family. *It will be a good break before I get neck deep into this project.
It's probably going to start out a bit slow - I'm still getting the shop set up, still have to get my occupancy permits, waiting on a couple more things and I have to start getting my parts ordered. *Once it comes together, I should be able to run with it pretty well.
The first cars will, obviously, take the most time to build. *I'll be building jigs for them, for the suspension components and such too.
I'll keep adding to this thread as I move along.
Old 12-26-2006, 12:02 AM   #23 (permalink)
renegadespec1's Avatar
Looks GREAT K-fab...wanna adopt me?
EVIL 6's LOOSE CANNON
renegadespec1 is offline   Reply With Quote
Old 12-26-2006, 12:50 AM   #24 (permalink)
hell of a shop, you got there. *can i be your adoptive dad? *
seriously, *good looking shop. *good luck on your new venture.
Bedo is offline   Reply With Quote
Old 12-26-2006, 01:13 AM   #25 (permalink)
BANNED
Anyone told yoshi yet?
Old 12-26-2006, 01:17 AM   #26 (permalink)
lmao, if yoshi can do it, surely k fab can, hes going to have lifetime suplies of bubble gum tho....
Old 12-26-2006, 01:53 AM   #27 (permalink)
Glad to see someone that has so much knowledge get into manufacturing.
seems like a lot of clueless builders out there
THUMPCRAFT is offline   Reply With Quote
Old 12-26-2006, 02:33 AM   #28 (permalink)
Super Moderator
rowycoracing's Avatar
Best of luck to you in your new endeavor K-fab. *It's very exciting to start new venture.
Old 12-26-2006, 03:46 AM   #29 (permalink)
Admin
Kludge's Avatar
Default Re: K-fab Short Course Super Buggy
Hey K-fab,
Go for it!
I know we will all enjoy your adventure.
Best of luck to you.
/Frank
Kludge is offline   Reply With Quote
Old 12-26-2006, 04:35 AM   #30 (permalink)
rxpo's Avatar
Short Course Car *
Sand Car *
Desert Race Car *
Wow, You have my attention.
It took me 3 years to *complete my little circle track/trail minibuggy.
And during those 3 years I have been absorbing info on these forums, as well as what I learned hands-on.
I have been dreaming of moving onto a long-travel MC powered sand rail then a desert runner.
rxpo is offline   Reply With Quote
