Old 03-05-2008, 12:41 AM   #101 (permalink)
bdkw1's Avatar
Default Re: Midi-buggy
Originally Posted by busasandrail
Did some additional searching and found you need at least 1 degree offset to keep the needles bearings rotating.....so 2 degrees should be good.
Another reason for replacing the needles with bushings.......
Originally Posted by masterfabr
I'm wanting a cushioned drive coupling.I wonder if I could inject polyurethane in place of the needles.Maybe machine the cross shaft into a double D shape to more effectively transmit the torque loads.
Buy a Goldwing motor, they're built in *
Old 03-05-2008, 12:47 AM   #102 (permalink)
busasandrail's Avatar
Would you run into a similiar problem with doing a bushing? Wouldn't it dig a grove it to the bushing?
Seems to me that the u joint would be an easy replacement and more so if its a stock over the counter item....
Nothing is impossible---it just costs more money.
EL TORO sand car w/(soon to be) TURBO 1397 Busa / Subaru STI diff. / cutting brakes
www.eltorosandcars.com
Old 03-05-2008, 05:26 AM   #103 (permalink)
BDKW1. I used to be a crew chief on a blackhawk helicopter. I see that there are questions and comments from others about what to use for power transmission between the goldwing engine and the diff you are using. What sikorski designed for very low angle power transmission joints is a flexible coupling. The coupling consisted of 10-20 .030-.040" stainless steel disks stacked together. This arrangement allows for a very strong joint with some flexibility. I see you have already found the solution you are happy with, but if for some reason it doesn't work the way you'd like it to, this might definitely be an option.
Here is a pic of the flex-pack installed on a blackhawk. It took me almost an hour to find this picture, and if I could have found a better one I would have used it instead. I hope this at least gives you an idea of what I am talking about.
PilotHawK is offline   Reply With Quote
Old 03-05-2008, 12:53 PM   #104 (permalink)
masterfabr's Avatar
Doesn't that just allow for angular misalignment and not radial or axial?
Old 03-05-2008, 05:28 PM   #105 (permalink)
bdkw1's Avatar
Pilothawk, Interesting, kinda like a steering rag joint on steroids.
Old 03-05-2008, 05:56 PM   #106 (permalink)
bajatex's Avatar
Why not use a "hardy" disc like the BMW and Mercedes use in their drive shafts? Wouldn't this work for this type of application?
bajatex
bajatex is offline   Reply With Quote
Old 03-05-2008, 06:30 PM   #107 (permalink)
masterfabr's Avatar
Yes,got any better pic or dimensions?
Old 03-05-2008, 07:57 PM   #108 (permalink)
plkracer's Avatar
Almost any rwd car uses them. They should work just fine, but you would need to make the adapter to fit them. It has three prongs that bolt to it.
It finally moves!
Old 03-05-2008, 08:57 PM   #109 (permalink)
What about a lovejoy ?
"Anything is possible, it's just matter of TIME , MONEY & THINKING out of the box"
Old 03-05-2008, 09:02 PM   #110 (permalink)
here is a pics
